2001/W Xantia (ie mk2).
I wanted to get a new ignition key, so went over to the dealers who ordered one. The immobiliser then needs telling that the key is good, but apparently the car has had an ECU change in the past, and all paperwork related to this has vanished, so the dealers were unable to complete the job.
I've now got another dumb key which won't start the car. Is there any way out of this, short of replacing the ECU again (not an option...)?
Xantia replacement key
meexi
Re: Xantia replacement key
if you open the key you will find a little rectangled bit of metal swap them over into your new key and then it should work
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
evilclive
- x 3
Unfortunately I want a spare key, so that's not going to help
meexi
tape the bit of metal next to your ignition switch
evilclive
- x 3
I have actually considered that. Are there any downsides to that apart from the obvious security problem? Eg does the car say "your key's still there" when you switch the engine off and open the door?
meexi
never thought about that
DickieG
- Monaco's youngest playboy
- x 38
How easy is it to prise out the transponder from the key without damaging it,,,,,,,,
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1056
If the ECU was replaced it should have been coded with the same access code as whats originally in the CPH otherwise the car wouldn't start ?evilclive wrote:2001/W Xantia (ie mk2).
The only way the code can be changed is if the ECU and CPH were changed at the same time, you would then use Lexia to tell it the new code & both units must have the same code. I cant understand why anyone would have changed the code ?
Another solution is to take the key along with a working key to an auto locksmith, some types of transponders can be 'cloned'. I believe some branches of timpsons have this kit.
evilclive
- x 3
In case anybody is interested, I had another go with the key blank from the garage and the key code they had with my lexia. First attempt failed again, but I then asked somebody if the code the garage had given me was correct and it transpired it wasn't - or at least my reading of the code wasn't. Tried the right one, now I have a working spare key
I suspect the garage made the same mistake I did.
