205 CHOKE
205 CHOKE
Hi I am doing up a 1988 205 junior for my daughter to learn to drive in and noticed that even when the engine is warm if you push the accelerator to the floor, the choke knob partially comes out is this normal? the car has a 1000cc tu9 engine. thanks in advance Jerry
Stop looking!
It is due to the assembly`s of both being connected and one is touching the other. As long as the choke goes back in then it will be OK, get someone to have a quick look to see that everything is OK when you have time (and a mate who can look for you while you push the throttle, engine off i would advise)
