This weekend we swapped the heater matrix is Xac's Cassy. The elbow connector was stuck so fast we broke it getting it free. It really, really was stuck very fast as even when broken it was very reluctant to part company...
Xac had formerly used K-Seal in the system and I believe I may be on to something here. A common factor, I believe, is that in all recent cases of broken elbows I've been involved with, a common factor has been the use of a rad sealant other than Forte Stop Leak..
I may be barking up the wrong tree here (or just barking) but theres a growing body of evidence in my mind to suggest these sealers weld the matrix connector together and make them almost impossible to separate.
I've used Forte on a leaky matrix and in that case the connector did come apart...
I'm no fan of K-Seal and it's ilk and even less so now...
Also, I'm reasonably sure now that all that happens to a Xantia matrix to make it leak is hard O rings on the inner flange; That was the case with Cassy's most definitely... Her rings were as hard as iron..
Next time it'll be worth really trying to just replace those O rings (they're a standard size) without disturbing the elbow. If it fails though, it'll be a sod give the dash will have to come all the way out again...
On Xantia Heater Matrix Elbows and Rad Sealants...
- x 8391
DickieG
- Monaco's youngest playboy
- x 38
Re: On Xantia Heater Matrix Elbows and Rad Sealants...
Unless you test it by running the engine before you refit the dash, you can of course connect up the dials without refitting the whole dash.CitroJim wrote:Next time it'll be worth really trying to just replace those O rings (they're a standard size) without disturbing the elbow. If it fails though, it'll be a sod give the dash will have to come all the way out again...
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8391
citroenxm
- Fallen Hero
- x 70
S2 matrix's are a little easyer to do I find, more with the dash removal...
Anyway... I am a STRICT non user of any sealer what so ever in any car system! If theres a leak it gets done as soon as and not put off!!
Its a COP out useing sealent..
Did you remember to split the heater box from the blower house on the middle?? Makes the job a bit easyer and is only two 10mm bolts.. top and bottom
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xaccers
- x 188
Well, we haven't done Jenny's yet...CitroJim wrote:Yes, that's a good thought Richard...
We need a guinea pig now.. I wonder how the matrix is on my soon to be arriving HDi?
Note: This is not an invitation for me to do anyone else's leaky matrix... I've done enough now to last me several lifetimes![]()
DIY sphere tool
DIY sphere tool
- x 8391
citroenxm
- Fallen Hero
- x 70
- x 8391
Oh yescitroenxm wrote: Did you remember to split the heater box from the blower house on the middle?? Makes the job a bit easyer and is only two 10mm bolts.. top and bottom
addo
- Sara Watson's Stalker
- x 95
- x 8391
lexi
- x 134
Well I have a slight curry smell in this MK 11 V6. Got a whiff about 4 wks ago and put Forte in it. It still smells when heat put on for first minute.
I aint doing no matrix now . I think every Xantia at 12 yrs old has duff matrix or rings
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Dommo
- x 20
Mine does this and has done for the past 13 months, not put any sealant in although a previous owner may have, I don't imagine you'd know until you do a job such as this. I need to get it done one of these days but don't fancy it at all!lexi wrote:Well I have a slight curry smell in this MK 11 V6. Got a whiff about 4 wks ago and put Forte in it. It still smells when heat put on for first minute.
Xaccers
- x 188
Eventually you'll get mist coming out the vents and even having the a/c on won't stop the windscrean from fogging up.
DIY sphere tool
DIY sphere tool
DickieG
- x 38
lexi
- x 134
Cheer us up why don't yaEventually you'll get mist coming out the vents and even having the a/c on won't stop the windscrean from fogging up.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
