I haven't bled the brakes altought it might be worth doing...are the rears more queationable than the fronts?Old-Guy wrote:You've answered your own question - at least in part. You need to sort out the rear height adjuster mechanism so that the lever moves as easily as in your other car. Personally, I wouldn't start investigating spheres until you've dismantled and thoroughly cleaned up the mechanism.XantiaDaveEire wrote:I meant when manually adjusting the height from inside the car to high and low it can be slow at the rear to adjust heights,the lever is hard to move into the high position ,it takes two hands two pull it all the way up compared to my silver car it will move up with ease..Is there anything i could do to try and free it up ?
Final thought: did you thoroughly bleed the brakes when you changed the spheres (you need to pump about ½L through each rear caliper as the rear brakes get their pressure from the rear suspension, to clear out all the old LHM.
Poor xantia comfort and ride
XantiaDaveEire
- x 4
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k
aerodynamica
- x 216
55 psi (sic) pressure at the front? that's a BX sphere you have my Son!
I am sure the Xantia should generally have 70(odd) Bar pressure on 400cc-sized spheres with whatever damper is specced for the model in question. The rears are something like 35Bar pressure. I recall this from the Citroën spec. sheet for the spheres for the various Xantia models.
Thing is, even with BX fronts fitted, the difference in ride will not be so severe as to cause these large observations. I think you either have massively over-pressured spheres (like over 70b) or the spheres are new but duff. (or they've given you hydractive corner 'sport' spheres by mistake)
I found this out with my old BX16 TRS; I had new front spheres for it: 55bar, 400cc 1,9 marked damper but just for experimentation, i temporarily fitted my CX fronts to the BX for a trial. These are 75bar, 500cc but the same damper.
The larger sphere volume with the same damper should give a softer FEELING ride as the spring rate-of-change-per-stroke is shallower, but only if the pressure was about the same (55bar), but of course the CX has 75 bar and this turned out to give a horrible, crashy ride. Why is this? It turns out to be due to the fact that 75 bar on a BX, is too close a pressure to the pressure of the LHM holding up the front suspension (guess it's about 80b or something) and as such, when standing static, the sphere is still 'uncompressed' when the car is at normal height; the pressure needed to hold it up is not enough to move the inner sphere diaphragm to its idealised 3/4 position away from the back of the damper. It leaves not enough LHM volume in the sphere for the gas to push the strut down a pot hole: the diaphragm in the sphere was too close to the back of the damper and where a pothole was met, there was a sharp, hard jolt where the LHM went to a spike of negative pressure as the diaphragm whacked the back of the damper. You could replicate it in the garage by bouncing the front - if moved down plushly but to try to lift it up; it kind of 'jammed'.
refitted the lower pressure spheres and all was restored.
If I'd found CX fronts that had lost some pressure down to say 60bar from 75, they'd probably have given a supreme ride as there would be a full house of ideal states: larger (500cc) sphere volume, fairly slack (1,9) damper and a higher than (BX) standard pressure to give more gar volume to play with in static conditions.
Presently I have a pair of CX Turbo fronts on my Xantia 1.9 TD non-hydractive, These have a slightly firmer damper to the standard CX saloon but the same pressure and volume. I had these regassed to 80bar over the normal 75b. a year back and this gave the best ride ever. On the Xantia, the heavier diesel engine allows for the use of the higher pressure spheres and they perform brilliantly. (by good luck the CX Turbo used a similar damper calibration to a standard 1.9TD Xantia) the bigger size of the CX spheres allows for a softer spring over the travel of the suspension compared with the smaller 400cc size standard for a Xantia.
Coupled with the standard rears of the Xantia these CX fronts don't seem mismatched but I'm keen on using slightly higher pressure spheres on the rear too. Say, 40bar instead of the 35 standard. I'm fairly sure this will give a softer spring with sensible overall damping and motion - only the strut piston diameters and trailing arm-to-piston-pushrod leverage ratio would remain an unknown factor, but I bet these are not massively different to the BX and that model used 40b, 400cc and 40b, 500cc on the estate.
I am WAY too interested in spheres and such....
That's true! but it depends on the weight of the car: if they're 20 bar too low, it'll make it a bit 'rubbery' but will still ride well. If it's 20b too high you might get a phenomenon where the suspension seems really soft to press down on but will not allow any 'drop' to the wheels for potholes.20bar increase is huge, too much pressure and it will ride awfully.
Graeme M
DickieG
- Monaco's youngest playboy
- x 33
Apologies for the correction Graeme but the 70 Bar sphere's are for 1.8 and 1.9D Xantia's, TD's and 2.0 ones have 55 Bar sphere's at the front, rear pressure is either 30 or 40 Bar. For a full table of sphere's look at this linkthen click on Technics, Technical data then sphere's.aerodynamica wrote:55 psi (sic) pressure at the front? that's a BX sphere you have my Son!
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
aerodynamica
- x 216
HDI
- x 7
This is sounding uncomfortably like it may be the problem with mine
Doesn't Plaides have a good rep for spheres though ?
I would have thought out of all the aftermarket suppliers they could be relied upon to supply the correct spheres for a specific model ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
XantiaDaveEire
- x 4
The main problem i'm having with mine is that the rear is slow to adjust heights and uncomfortably hard when drivingHDI wrote:This is sounding uncomfortably like it may be the problem with mine![]()
I'm going to take two videos of both my cars and post them on here to see if that might make things easier to diagnose,because i've got spheres off the same company before and they were fine .
I'll try and get a video up as soon as i can
Dave
