Schematic wiring diagram needed
Tebster
Unread post by Tebster »
Hi,
Can anyone help me out with a wiring diagram for the aircon / climate control on a 99 citroen Xantia 1.9TD.
Thanx in advance
paul
Richard Gallagher
Unread post by Richard Gallagher »
I have the genuine Citroen Xantia air con manual and its not in there!
Tebster
Have got the pre 98 diagram but unfortunately there are some major differences.
AndersDK
Unread post by AndersDK »
Tebster -
Is the pre '98 (facelift) schematics the same as found here ? :
http://citroeny.cz/servis/xantiaser/xantia.html
Tebster
Thank you andersdk,
Unfortunately have already looked at this diagram but it shows the air con relay (8015) that is switched by the positive, on my later xantia it is switched on the negative side,if I could find a diagram for the later xantia's it would be a great help in solving my electrical problems, as am quite sure what ever is causing this relay to buzz is also causing my other problems, please read my other post on intermittent tacho / diesel clatter.
Thanx
paul
