Suspension quirks and more...
KevMayer
Unread post by KevMayer »
My first Activa used to make a vibrating noise on accelerator lift off and I found links on the web etc. which explained that it was characteristic of a failing top engine mount.
The top mount is a complicated arrangement. With the bonnet up and you infront of the car the mount is roughly on the left between the sphere and the timing belt cover.
When I got my second Activa (now owned by Citroenmad) the previous owner proudly told me that he'd changed the top engine mounting because of a vibrating noise (at between 2000 to 3000 rpm on lift off).
Hope this helps.
Cheers, Kev
jwalshe
Unread post by jwalshe »
Thanks Kev - really appreciate that! Any idea if it's an expensive job?
Cheers,
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
jwalshe wrote:Any idea if it's an expensive job?
DickieG wrote:One other thing to consider with an Activa is the top engine mounting where it attaches to the inner wing, it could be misaligned or the rubber bush split which is quite common, a new mount is roughly around £25 IIRC.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
jwalshe
Including fitting??? :-) Hmmmm
I guess you're assuming I can do the job myself... haha!
I'll seek out a Citroen garage and ask em.
Cheers,
DickieG
x 33
It doesn't take long to do, an hour at most.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
jwalshe
Ah, cool - cheers! Will seek out a local Citroen specialist to do it. Certainly not going anywhere near a main dealer! :-)
DickieG
x 33
I take it you're going to Little Horwood this weekend, if so make contact and I'll have a look at it although its not easy to see splits until its almost removed, I'll be in XAN71A with a Canon 5D hanging on my shoulders
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
jwalshe
Cheers Dickie! I'll be the geek with the Canon 60D around my neck ;-)
DickieG
x 33
jwalshe wrote:Cheers Dickie! I'll be the geek with the Canon 60D around my neck ;-)
Excellent, you can give me a few tips :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Does this mean everyone else will be gawping at the double D's? :P
*ducks, then runs out quickly*
holmedog
x 5
Unread post by holmedog »
i have this problem with my activa and someone told me it could be the turbo stalling or even spinning back1
as the exhaust gasses build up the pressure and has no wayof excaping this can cause these problems.
this is what i was told could be wrong. any thoughts on that anyone.
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
jwalshe
Hi!
In my case, the guys here were totally spot on with the strange noise. Had the top engine mount (the one next to the bulkhead) replaced and it was fine after that.
Took my mate about ten minutes to do - the part cost me £28 from a Citroen dealer.
The old mount was in a terrible state on removal - it was all cracked and loose.
Sl4yer
Re:
Unread post by Sl4yer »
Get the bottom mount looked at as well in that case - chances are it's gone soft. You'll kill the top mount in a matter of months if the bottom mount isn't up to scratch.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
