Has anybody got any views on which is best?
I have recently bought a Valeo water pump from ECP in preperation for a cam belt change on my wifes C5 2.0 HDi - I chose this over the cheaper Circoli pump as I thought it may be better quality. The Valeo has a plastic rotor and a Circoli pump which my daughter has waiting to go into her Xantia HDi (same pump) has a metal rotor.
Have I paid more money for a lower quality pump or have they resolved the historical issues with plastic rotors?
I've tried to find out from the Valeo technical people what type of material is used in their rotors but they have no idea.
Water Pump rotor - plastic or metal?
wotwot
- (Donor 2021)
- x 4
addo
- Sara Watson's Stalker
- x 95
I'd suggest plastic is not a good idea if your pump changes run by years not mileage (ie; when four years are up the mileage is not at the recommended change point). Many plastics seem to be embrittled by the action of dissolved chemicals - another good example being the heater pipe elbows.
The other caveat on plastic fins, is freezing - I'd much prefer a metal impeller if there is possible ice or sluch in the system!
