'99 Peugeot 206 1.9d green light only
Post your Cit/Peu/Ren air conditioning queries or advice.
Edhertz
x 4
Unread post by Edhertz »
Here's hoping someone can help me with this one. My '99 Peugeot 206 1.9D's air con does not work. Took car to Kwick Fit who said that they found a low refrigerant level in the system. They topped it up, but could not get it to work so they kindly didn't charge me. This is what I have at the moment: green light comes on when the a.c switch is made , no compressor engaged or fans running, belt is driving ok. I pulled the connector and found no power to the compressor clutch. Removed the pressostat connector and bridged the two thicker wires (beige and pink) and the condenser fans came on, with no power to the clutch. Checked all fuses and relays and they are healthy. Thinking it could be disconituity in the wiring or one of the system sensors gone down. Any ideas anyone? Thanks for looking, Alan
Greasy
New User
Re: '99 Peugeot 206 1.9d green light only
Unread post by Greasy »
Check the pressure sensor if the correct presuure is not sensed the compressor clutch will no activate
hope this helps
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Also, a no-spin condition on the cabin fan will result in no signal to the compressor.
Did Bodgy-Fit leave the gas in, or restore it to the original pressure as measured?
Edhertz
x 4
Firstly thanks for replies. Havn't done much more as regards finding the fault to tell you the truth. Weather has been so damn lousy we have not missed it. Things are going critical now, however, because the boss ( her car) informed me that the blower has stopped working so I've got to come up with something. So to recap: system gassed up, now no green light showing when a/c switch is made and no fuses blown. From memory: no voltage at prestat, continuity through the presstat so a 12v fly lead to should engage clutch but I have not tried this yet. Funny how the blower should wrap up at this time unless there is wear in a section of harness. Before I go does anyone know where the aircon relay is?
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
