Hdi 2.o 8v 110bhp.
Cooling system problem. NEW Thermostat HAS been fitted. Cooling system flushed and filled.
Whats happening is one moment all is well, the Rad is warm to hot evenly all over, then suddenly the Temp Needle shoots up off the guage and the warning message "excessive engine coolant Temp"
If you get out the car and check it, the rad has gone cold, but the top hose is hot, and so the lower... When the cooling fan top speed goes off, it then is all ok again!!
Blocked Rad?? Faulty rad even??
Any ideas peoples??
Paul
Oh, ALSO, it also has a blower fault! It stays on full speed. On these C5's the speed resister is an external unit to the blower, which I have found over by the clutch pedal.. so it ALSO needs one of those!!
