2.1 XM - V - 110hp 406
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Peter.N. wrote:That uses fuel :shock: I have actually given the 406 a short blast at full throttle and it did eject a bit of soot so that maybe the problem, I will try it again when I can afford it :D
The 406 will pull away well at tickover but if you drop to about 1200 rpm when driving its gutless whereas the XM will pull quite well from that speed.
Definitely something not right there Peter, HDi's produce more torgue at lower rev's than a 2.1, think of the money you could save if the engine is breathing correctly :lol: Joking aside it might be worth giving the cat a sensible knock prior to the Italian tune up to dislodge some of the built up soot. Citroen did produce a service bulletin on this very matter of the cat being blocked with soot.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
RUBBISH Peter, In the Old XUD yes a hard plod resulting in black cloud of smoke, but in these HDi I simply CANNOT get a cloud of smoke from the exhaust (Once the exhaust soot has cleared)
I only get a grey Haze.. remember these HDi's use minimal amounts even at high revs.. No wasted fuel resulting in black clouds!
Paul
A very sad...
1994 XM 2.1 d auto
x 1240
Unread post by Peter.N. »
I think it probably was soot Paul but nothing like the thunder cloud I get when I do the same to the XM.
Dickie
Its doing 60+ mpg so I'm not going to complain at that but it certainly doesn't pull at low speed like the XM.
x 1485
My HDi 110 pulls much better at low revs since I changed the cambelt - no idea why, the timing appeared spot on before and after, but it used to judder if you asked anything of it below 1250, but now it's fine :? . 50 mph = 1750 rpm in top in a Xantia HDi 110 (or any speed you like in mine, as the speedo reads 50 most of the time anyway :lol: )
