Pulled up on my folks driveway, and whilst waiting for them to answer the door realised that the front was only just above the wheels. The rear a little higher. I assume where it should be.
Did a bit more investigation when I returned to the car, and the rear rose a little on start up, but the front did not move.
Car will go up and down if you utilise the height controller, but does not seem to be as high as it should be on standard driving.
Are there any tests that can be done to confirm my thoughts, and likewise what do you think could be at fault.
Thanks again
- Dave -
