Veg oil ?
x 1484
Stick a tank of dino in it and see if the problems go away???
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
yep Maybe Richard.. pretty sure they would...
microscope? ;)
bostwickenator
Unread post by bostwickenator »
You know if I was having that much trouble I'd just go to BP. Can you get yourself some filters and filter the oil as you put it into the tank?
x 2941
My pal who ran his 406 on used chip oil from cafes had a set up in his shed where he cleaned it.
One ten gallon plastic barrel with a tap set six inches from the bottom, he let the stuff settle until all the sludge was below the tap level then from the tap through a coffee filter into a clean barrel.
That seemed to be all that was needed, he did about 80k miles on that without any problems (except that the bloody car always smelled like a chip shop) :)
jgra1
(Donor 2021)
x 36
ahh it's no bother, to be sure :) changing the filter is a 1 min job.. and I get a warning (about 30 miles) before it's going to need it.. even at £4 a week for the filter, I am still saving a lot more than using Diesel..
the point of my hijack, (sorry :twisted: ) was more to see if I could have finally done some damage to the pump after so much miles/time.. i.e. whether the pump was loosing it's ability to draw the fuel from the filter and thus giving the symptoms of a blocked filter...
Looking at the filter I removed on Monday, it's clear to me (sorry) that the last batch of oil I brought must be the culprit.. with that in mind, I will empty the final barrel in, stock up on more filters, and then see how the latest batch of barrels behave..
I never shake the paranoid feeling that pouring food into my tank will always be safe, even after 50 tankfuls :lol:
John
