Hi, my daughters c2 has a problem, when the car starts the side and dipped beem come on!!!! it doesnt have auto lights on it either. I can switch it to sidelights only and onto dipped beam and flash the headlights to make them come on.
Does anyone have any ides what could be causing this to happen????
Oh, and I have disonected the - termianl for 45 mins to reset the ecu....
Help please
Paul
C2 headlights problem
wrinklet1
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
- x 1489
wrinklet1
- x 1489
Sorry for being obtuse Paul....
The COM2000 is the column stalks unit that sits behind the steering wheel. It used to be called that in the early days of multiplexed cars, and failure was common - causing all sorts of lighting oddities! Unfortunately both stalks are in one unit so have to be replaced together, so it's not that cheap - and if the car has ESP it needs to go on a Lexia to configure the steering angle sensor. I'm not sure how you'd diagnose it for sure - perhaps on a Lexia it will tell you the position of the switches, which won't match the actual position - although quite why they should only come on when the igntion is on is a bit of a mystery as I'd have thought they should work all the time... maybe not on one of these new fangled beasts
wrinklet1
