Bootlid brake light
froggy
(Donor 2026)
x 4
Bootlid brake light
Unread post by froggy »
Hi, my Xantia bootlid brake light has just failed. How do I acess the bulb? iI have undone the plastic cover on the inside of the boot lid , but Iam unable to reach the bulbs . any help gratefully received. cheers Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 8298
It's a game Terry.
The light is held in with spring clips. Basically you need to remove the bung you have seen and then using quite a large, wide pry-bar in the hole depress the clip on the side on the lamp whilst simultaneously trying to pull the edge of the lamp out of the boot. It's not easy... It all has to be done by feel and gymnastics. It helps if there are two of you to do this. Once you have one side on the way out the other follows sweetly.
The bulbs are just normal capless 5W jobs, the same as used in the number plate lamps, sidelights and interior lights and so on.
After renewing bulbs the lamp snicks back into place with ridiculous ease...
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
If you haven't got a pry bar a 3/8" socket set extension works a treat.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 5651
A lad at work replaced all the bulbs in his Picasso HLBL with LEDs.
They were so dim as to be useless - they were blue and the red filter blocked all the light.
