Hi all
I would expect my 406 to ride hard compared to an XM but it even seems hard relative to a ZX. Its OK on main roads but round the lanes here you seem to be able to feel every bump. Firstly is this normal, secondly, is there anything I can can do about it, are there softer springs I can use for instance? I have tried lowering the tyre pressures a little which improved it slightly but not enough. Otherwise its a very nice car. I would be interested in your thoughts.
406 Hdi hard suspension?
- x 1240
- x 94
- x 8234
Malcolm! You of all peoplecitronut wrote: ...had proper rear susp (spring and shockers)
The only suspension I've seen on a 406 is the coil spring one. Surely a terribly retrograde step backwards from the torsion bar set-up on the 405.
The only 406 (saloon) I've driven I found it horribly like driving an overstuffed sofa; far too soft and wallowy. The dampers felt as if they were full of lard.
Is yours an Estate Peter? I believe, like its 405 predecessor, the estate is set up that much stiffer and firmer for load carrying duties.
Maybe if the rear suspension layouts are the same then perhaps a swap to saloon springs and shockers might help.
Truth is though Peter, after the delights of Citroen hydropneumatic, nothing quite compares to it...
Thing is, ride apart, I really, really rate the 406 as a great workhorse of a car that is almost spot-on in every department bar one.
Toby_HDi
- x 3
I can't comment too much as the Coupé suspension is probably even firmer again and the ride height is lowered compared to saloons and estates. Plus, mine isn't exactly 100% anyway.
Thing to note though is that after driving the Coupé, my Xantia was superbly comfortable. So much so that I hadn't noticed it was stuck in firm mode! I only found out when Jim discovered a rear electrovalve fault on the ELIT.
Could this be contributing Peter? As Jim says, nothing compares to hydropneumatic and you are used to XMs after all
Failing that; bushes, links and shocks would be my guess. Tyre pressures are one to check too. The Coupé, at least, is quite sensitive to tyre pressure changes.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- x 94
my brother inlaw's V reg HDI EXCLUSIVE was extreemly harsh in the suspender department, but my daughters old P reg estate was very commfy/soft,
also i have seen 405's with both types of suspenders, coils and toursion bar,
and prety sure i have seen 406's the same,
regards malcolm
- x 1240
Thanks all for your comments.
I would be delighted if the suspension was like a sofa with lard dampers I wouldn't even mind if it leaned on corners as long as I didn't feel every bump. Its an estate by the way but the suspension feels similar back and front.
I have to drive over a forest track to reach the road which is full of potholes so I can find ones of appropriate size and depth to compare front and rear ride and as I say its about the same front and rear. There are no rattles, or at least not since I changed the tie rods.
I thought it was just me having only driven XMs for the last 15 years but I drove a ZX estate the other day that used to belong to my wife and even that was better. I suppose it could be down to the tyres but I don't feel inclined to by new ones on the off chance.
You couldn't feel a thing in my Morris Oxford with cross plies
addo
- Sara Watson's Stalker
- x 95
- x 1240
- x 94
Toby_HDi
- x 3
Electronically managed suspension only an option on Coupés here in the UK I believe. Even then not for very long. It's apparently rubbish.
Toby
Previous:
Previous:
addo
- x 95
I am fairly sure it was a European option on saloons/estates; had assumed this case in the UK as well.
605s have it, and I don't rate this gimmick especially highly. The principle is sound (basically, variable valving in each shock body, rather like toggling the centre Hydractive sphere) however it just doesn't have enough range for finesse. The result seems to be compromise on any road at any speed!
Perhaps, Peter needs his suspension checking generally?
Also the HDi here ran 16" rims as opposed to the 15" wheels of other models. Yet another bit of buffering lost...
- x 1240
No, 15" rims with 195.65s same as the XM. I have replaced drop links and tie bars at the rear and everything appears to be in good order. Dampers ar OK, it might ride better if they weren't. Somone I gave a lift to the other day said how nicely it rode compared to their car - so perhaps its just me and about 25 years of hydropnumatics.
