LHM
Post Reply
tonyb1
My Cars:
LHM
Post by tonyb1 »
Doing my usual weekly check today I noticed that the LHM indicator was above the top line mark. It was ok last week [:0] I know for a fact that there's no leaks and the suspension is excellent [:)]. I topped it up with about 25cl of LHM but it had no effect? My neighbour who used to have the same car tells me that the indicator can stick in the top of the little dome, he reckons that's what happened to me [:(] Is there any way of releasing the indicator? I'm also concerned that overfilling the LHM might have unwanted side effects [:(]
philhoward
Post by philhoward »
Overfilling will just end up with it coming out of the overflow...
To "release" the indicator, just tap it with your finger..on max height, of course!
AndersDK
My Cars:
Post by AndersDK »
Overfilling is VERY serious : you get messy fatty spots/pools on your driveway [:D][:D][:D]
- no serious problem [;)]
The indicator is sort of a bajonet fit on the reservoir. Carful bend aside a small plastic locking lug, and twist the base of indicator tube some 45-90 deg - and up it comes.
nick
My Cars:
Post by nick »
It always puzzles me how anything like this that's continually bathed in a bowl of oil can stick in the first place!
I think the indicator can be freed off if you remove the top plate on the reservoir (where all the pipes go in) and free off the float itself. Its been a while since I've taken an LHM reservoir to pieces so I may be wrong.
Overfilling with LHM shouldn't cause any problems. The worst that happens is that fluid dribbles out of the top of the reservoir and down the inner wing on hard cornering. Its messy, but really just a bit of extra rustproofing - LHM doesn't strip paint like 'normal' brake fluid does.
Nick
tonyb1
My Cars:
Post by tonyb1 »
Thanks guys! Had me worried for a minute Anders!! :-)
Kowalski
My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Post by Kowalski »
Did you have your suspension set to the highest setting when you checked the level? I know this may sound obvious to some but it could explain why your lhm tank seems overfilled.
jeremy
My Cars:
Post by jeremy »
Also make sure the car is unloaded before checkinh the LHM. You will find that with a reasonable load on full height it will take a considerable amount of LHM due to compression of the spheres. Unload the car and then its overfull.
jeremy
Post Reply
