Not if there's no visible leaks.. When they go they really leak but they don't stop the pump basically working.wotwot wrote:Could this seal still be at fault or would i have diesel showing up somewhere.
Dispatch fuel pump
OnlineCitroJim
- x 8457
wotwot
- (Donor 2021)
- x 4
OnlineCitroJim
- x 8457
wotwot
- (Donor 2021)
- x 4
Well a eureka moment.
I've read this on another forum so i suspect something similar
The last owner broke down thinking he was out of fuel even though the gauge showed he still had some ? ?,called the AA.
The AA man tried to bleed the fuel system,and when he could get nothing from the injector pipes on the back of the pump thought he would bleed it from the triangle bolt on the side of the pump
The rest is history as they say.
As soon as i took the top of the pump for stripping i tried to push the governor plates they were stiff to say the least,looked at the pivot bolts and yes it had been undone and then done up but not in the hole provided
The material it is made of does not like to be straightened, it groaned as I bent it back to shape and cracked.
This has i assume caused stress to the plate which holds the two large springs from the distributor and is now in two after i dropped it on the floor that is.
These two smal springs would not fall out when i tipped it up on the bench,
on PULLING them out were half full of what must have been FAT.
So he must have been using chip oil (he was a bit lardy
Anyway do any of you guys on here have any internal parts off a Bosch pump I could exchange for beer tokens.[/img]
Sorry got the images in the wrong order the two smaller springs were full off fat.
these are not my imagesand are used for the purposes of this thread,i will upload mine when i get them off my phone.
Oh And heres that BLEED screw
wotwot
- (Donor 2021)
- x 4
Managed to get the photo of my damaged parts up now.
clearly shows the kink,
a full image
and did'nt notice before but i thought i had cracked it trying to straighten it,
but this was taken before straightening and clearly shows already cracked.
If anyone has this part out of a pump let me know i dont mind trying to repair
a full image
OnlineCitroJim
- x 8457
That was a bit silly of the AA man
Is that a crack in the lever assembly in the bottom photo?
Basically as long as it's just bent and not cracked then a careful straitening and checking that when it's mounted back on it's pivot screws that it's very free to move then it'll be very fine indeed. Only replace if that is indeed a crack.
If you do feel the need to replace it then the assembly is identical in any Bosch pump.
It looks a bit gummy in there so a good clean will not go amiss.
wotwot
- (Donor 2021)
- x 4
yes citrojim that is a crack.
Like i said I heard it groan when trying to straighten it but it was already cracked,
the pump was a little grubby inside,the small springs in the distributer located at the top of the pump were half full of FAT.
I hope someone on here has got an odd pump kicking around that i could scavenge the parts from.
I would like to see this through to the end now and not just give up and get another pump although if anyone has one of them i could release a few beer tokens in exchange for it
wotwot
- (Donor 2021)
- x 4
OnlineCitroJim
- x 8457
I have one of those pumps in my collection. It's ruined beyond belief having stood with some 'exotic' fuel in it but I reckon the bits you need should be OK.
Sadly, due to other activities it'll be Thursday before I can even get near it. If you can wait that long wotwot, I'll have a look...
That's amazing the plunger plate broke like that
It must already have been weak. Are the big plunger springs OK?
wotwot
- (Donor 2021)
- x 4
Thanks very much Jim, The offer of the parts is a godsend and would be appreciated.
We are in a hurry but we thank you for taking the time and effort to help out.
Just as soon as you can arrange getting to the pump to get the bits would be fine with us
Please PM me for address and details required.
You were up with the birdies this morning had gone out by 6.00 am so missed this reply.
OnlineCitroJim
- x 8457
OnlineCitroJim
- x 8457
Here's a good source of seals. I've dealt with them in the past.
Ignore that it's for a Volkswagen.. They're the same...
Brickwerks
They haven't half gone up. last time I bought this kit from thenm they were six quid or so...
Brickwerks
wotwot
- (Donor 2021)
- x 4
wotwot
- (Donor 2021)
- x 4
Thanks to citrojim his generosity and his parts emporium the pump is in one piece again.A much appreciated cuppa and a good chin wag many thanks Jim.
And my god you were right about the pump Jim it did'nt look petty inside.
I only used one section of the govenor plates the other two parts were been eaten by whatever was in there !!.
The replacement for the part that I dropped and which broke in half needed a little work before I could install it,a five minute work out on my finest sharpening stone cleared the "rust" or what ever it was.
Putting it all back together was worse than taking it apart.
Its now sitting on the work bench awaiting its transplant back into the dispatch
on friday.I'll get back and let you know how it goes or not for that matter fingers crossed.
There are other parts left over from this doner pump so if anyone needs anything from the pump let me know.
And this is the pump back together,I did clean it down but that black crud just dont come off,the bar code sticker came up clean ??!!.
And for those eagle eyed amongst you there is no STOP LEVER most odd.
The blank off where the stop lever would normally go.
OnlineCitroJim
- x 8457
That's great news
Very good indeed to meet you last evening! Sorry about the fishy smell in the kitchen. I found my daughter, when helping cook a feast on Tuesday had thrown the fish wrapping in the bin and this afternoon it was very 'high' indeed
Looking forward to hearing this Dispatch running very soon....
