Hi, would it be possible to remove the HDi pump and injectors On an HDi engine and replace with a non HDi system ie standard pump an injectors?
or is there something different about the engine ie compression ratios etc
that wouldnt allow it to run properly.
thanks in advance.
Nigel.
HDi Question Please?
DickieG
- Monaco's youngest playboy
- x 38
citroenxm
- Fallen Hero
- x 70
In a word NO
The injectors on an HDi do NOT screw in, they just "Sit" there but theres a Clamp that holds them in place...
HDi injectors are twice the length of ordinary injectors..
So really you would have to junk the head aswell and fit a DW8 Head, which does use a normal Roatry Pump and injectors screwed into the head.
When PSA designed the HDi engine the block is normal XUD block, but the pistons and head are completely new..
Anyway, why would you do that!!?? The HDi is smoother, better, faster, more economical and chipable!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1056
- x 8275
not least because ther HDi is a DI (Direct Injection) and the XUD is an IDI (InDirect Injection)
Pump, combustion chamber and injectror requirements are totally and utterly different for the two methods and are not at all compatible...
If you are intersted in the techicalities Nigel, I'll be more than happy to expand...
falling-out-with-my-car
- x 25
Jim, I didnt realise that the HDi was a Di engine, that has scuppered any thoughts of adapting a C5 to run on Filterted Waste veg oil then and I wouldnt want to twin tank it.
would it be permissable in these modern days to fit an indirect engine to a C5 a donor engine from an Xantia for example??
thanks for the comments thus far.
regards Nigel.
regards Nigel.
Deanxm
- x 87
- x 25
DickieG
- x 38
citroenxm
- Fallen Hero
- x 70
Thats all in the head design, however, due to being DI, the piston tops are "Holed" out with a solid centre... um, like a hollow channel... so weither a DW8 head would fit I dont know...
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 25
I know some insurance companies won't insure a vechicle if it has had an engine change , esspecially an engine that wasnt specifically designed for that model, if your replacing a standard engine with a new engine this is allowed, I was only wondering if it was possible to upgrade the body at some point thats all, just exploring the possibility.
I know for a fact Di engines hate the veg and you get what we call ring gumming. whereas indirect engines dont suffer with this.
High pressure diesel injection systems are a no-no with running veg oil apparently it mucks up the injectors pretty quickly that was my reason for asking.
regards Nigel.
regards Nigel.
