x 8427
Chris570 wrote:now i know i shouldnt be tempted
Chris, it's the same with the V6 and Activa. Once bitten, forever smitten :wink:
Not quite so much progress today due to the girls spending most of the day with me but I did get a bit of spannering done on Juliet. Her new Pressure Regulator is fitted as is her pump. Most of her engine bay ancillaries are refitted but time did not allow the fitting of the new cambelt or the fitting of the replacement pump to Old V6.
I did get some new tyres on Old V6. Got a good deal with some Bridgestones. No idea what they're like performance-wise by they're round, black, hold air and have tread on them - they seem to fulfill the basic role of a tyre. F1 cars seem to do well with them so I guess a V6 will too.. I do remember Bridgestones from my 70s Jap motorcycling days when they seemed to be made of a slipperier version of PTFE - bloody lethal in the wet! I hope they've improved since then...
They did as they said and used stick-on weights and they didn't do the wheelnuts up too tightly either. They seem to have done a good job as the car is silky smooth all the way to 80 without a trace of wobble or shimmy and the steering wheel is in the middle when travelling straight ahead. They seem a good bunch, this particular tyre fitting outfit, and are just at the end of my road...
Tomorrow a bit more spannering on Juliet but I'm determined to fit the new pump to Old V6 before the weekend. It's unlikely Old V6 will be all clean and sparkly for DSM now unless a miracle happens...
Citroenmad
x 110
Unread post by Citroenmad »
Bridgestones are pretty decent tyres Jim, I suspect they are ER300s?
Certainly get a better road test of many premium tyres, definitely the Pirelli P6000 which often gets slated.
I usually stick with Michelins but whatever deal looks appealing at the time with a decent tyre will do me very nicely.
Gareth: fancying another Activa already? I guess there is no staying away :lol:
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 8427
Citroenmad wrote:Bridgestones are pretty decent tyres Jim, I suspect they are ER300s?
You suspect absolutely correctly Chris :D They are the ER300. Hope they last longer than the BFGs they've just replaced.
Apart from their disappointingly short life, I found the BFG an excellent tyre, especially in the snow... It was a tad noisy though.
Hopefully the bridgestones will be a tad quieter too
Citroenmad
x 110
Ah, the big friendly giant tyres, not used them myself! BF Goodrich are usually pretty decent, though only 12K miles from yours? Thats heavy wear.
I usually find Bridgestones noisy, but Ive not used the ER300, these were the previous model.
03 Seat Arosa 1.0S
Xaccers
x 188
Unread post by Xaccers »
Jim, leave Juliet for a bit and concentrate on your V6 :)
I'm looking at alternatives to selling Juliet, I know I shouldn't but it's hard to let her go even if she is a MK2.
Maybe an LPG conversion, or a rent-a-garage for a while...
DIY sphere tool
red_dwarfers
x 58
Unread post by red_dwarfers »
Xac wrote: I'm looking at alternatives to selling Juliet, I know I shouldn't but it's hard to let her go even if she is a MK2.
Thats more like it Xac, just think of the ICCCCCCR next year. You'll want an Activa for that.
Citroenmad wrote:Ah, the big friendly giant tyres
Or if you played one of the Doom games in the 90s then BFG stands for something else :lol:
Kev
'19 C4 Cactus 130 Flair
Xaccers
x 188
I'd need a mortgage for the fuel bill!
Plus I have roof bars for Cassy but not Juliet or Jenny, and we'll need an empty boot for the dog :)
DIY sphere tool
Citroenmad
x 110
Ah, its not all that far from you, im sure if you have a fuel tanker in tow you might manage on one tank full :roll:
Im driving my Activa to Milton Keynes tomorrow, Im further North than the Harrogate show ground ...
I say keep the Activa, they are not worth anything to sell on anyway.
03 Seat Arosa 1.0S
x 8427
Been a good spannering day today :D
First off I replaced the HP pump on Old V6 and then found I really didn't need to :twisted: The leak finally revealed itself as a tiny split in the rubber stub pipe on the feed/suction pipe which grew until LHM flooded out all over the nice, shiny new pump.
I had my suspicions it was the stub pipe but the crack was initially so tiny and under the Jubilee clip that it was impossible to see.
Initially I was a bit niggled I'd wasted an hour swapping a perfectly good pump and having spent a lot of money having my spare refurbished unnecessarily but once I fired up, I found I hadn't. the 'new' pump is a lot quieter and it gets pressure up a lot faster. Also, to measure the tick rate I had to dig out my radio-carbon dating equipment...
Swapping a pump on a V6 is no trivial matter. the ECU box has to come out and then, because of access, a lot of it is done by feel and blind faith. Mind you, after the Activa exhaust manifold I'm sort of used to doing things in very confined spaces now.
Next week I'm going to decorate my hallway and do the entire job through the letterbox...
After Old V6 was sorted I resumed work on Juliet. I'm delighted to say she's now all done bar needing filling with coolant, having a new battery and the CV boot. Xac brought me a boot today but sadly it was the for the wrong side. The driveshaft diameters are very different on each side.
Juliet's cambelt tensioner was well past its sell-by date. It was both very sloppy and rumbly... We now know why the cambelt was so floppy :twisted:
I nearly had a disaster though. On disassembly we found the auxiliary belt tensioner was a bit stiff and this made the belt very hard to remove. For reassembly I 'worked' it a bit with a small breaker bar in the square hole and it came good :D I then went to do it one more time to fit the belt and crunch! Ping! a bit of the casting around the square hole broke off and flew across the driveway :evil: This sort of made the square unavailable and basically it seemed impossible now to set the tensioner so the belt could be fitted. Those tensioners have a hell of a spring to them and it seemed that whilst the tensioner itself was perfectly good, there was no way of setting it so as the belt could be fitted.
I tried a few ideas, all of which failed :( And then hit upon an idea after noticing the threaded hole where the jockey wheel screws in was about 3mm deep. Also, by the broken square was a smaller hole for pinning the tensioner in its released position. I made up a pin bar that would place a pin in each of these holes and I'm delighted to say it worked a treat :D :D In fact a heck of a lot better than using a bar in the original square hole. So, a potential showstopper turned out to be an opportunity to find a much better way of doing the job...
Here's a shot of the pin bar in place on the tensioner. It really makes light work of the job :D
Xantia V6 called over this afternoon in his E-Type to replace his driveshaft UJs. His car outside my house attracted a fair bit of interest and it was good hear a couple of young lads saying "Hey look, there's an E-Type!!!"
Others said "Thats a funny Citroen!" or words generally to that effect...
robert_e_smart
x 14
Unread post by robert_e_smart »
:lol: :lol: :lol: :lol: :lol: :lol:
I came across the same problem as your tensioner in a 2.0 16V XM, Fortunately on the Xm there is a small bar linking the subframe to the shell, so I could lever a crowbar against it to push the tensioner back, but I like your solution, I'll store that in the memory bank.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 8427
I'm happy to report Juliet is back in full running order and in quiet running order at that :D
I filled her with coolant, borrowed the battery from my Activa and went for it.
All as well, the new gasket and exhaust manifold smoked a bit, burning off all the Plus Gas and burning in the new gasket but no leaks of any sort.
The suspension is 1000% better. No dancing and no slow oscillations and height changes.
Just one small problem remains. The front electrovalve is a bit 'sticky' and sometimes he's a bit reluctant to switch to soft mode.
I gave her a quick MOT this evening and apart from the need of a driveshaft boot she's ready to meet the man from the ministry...
I'm wondering if the electrovalve may settle but if not I'll have it in bits and give the springs a bit of a tug...
We're nearly there :D
red_dwarfers
x 58
Not bad going Jim, you've put some serious work into that! I really do respect you!
Kev
x 8427
Thanks Kev :D Don't tell anyone but I've rather enjoyed it...
I did have one heartstopper though :roll: The Power Steering was all over the place at first, the wheel was hard to turn and all notchy. Worrying as the car has a newly reconditioned pump on it...
Luckily, it was a very simple problem and entirely my fault. I looked in the LHM reservoir and it was full of froth. I had a leak on the suction pipe to the pump.
I'd forgotten to tighten the jubilee clip on the LHM reservoir end of the pipe and it was drawing lots of air :roll: :roll: :oops:
red_dwarfers
x 58
CitroJim wrote: I'd forgotten to tighten the jubilee clip on the LHM reservoir end of the pipe and it was drawing lots of air :roll: :roll: :oops:
I've done that, though not before driving a good few hundred miles thinking that it was just the really cold weather taking its toll. :oops:
To be fair though, it wasn't exhibiting the classic notchy symptoms, just a bit stiff (really small bubbles maybe?!)
Kev
Chris570
x 36
Unread post by Chris570 »
CitroJim wrote:Thanks Kev :D Don't tell anyone but I've rather enjoyed it...
you were just testing to see if LHM and air would do the same job, they don't. You've learnt that now, but it was worth a go :)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
