The car was loaded with myself and wife and our luggage and our German Shepherd and her luggage, over the total distance of 1,853 miles we averaged 60.2 mpg, that was driving at a fairly steady 60 mph with the occaisional excursion to 70 mph down hills. We managed over 1000 miles on a tankful and I suspect the figures were actually better than that as the speedometer packed up several times and was not recording the miles travelled, when we refilled on the way home for 135.9p per liter at the new Asda store in Langley Mill, the 'mileage remaining' indicator showed 1212 miles, it had showed around 1200 on the previous refill.
I tried the effect of coasting down hills - purely as an experiment and it actually uses mor fuel! In gear with foot off throttle it counts to 999.9 then the display goes blank so obviously is not using enough fuel to register, knock it out of gear and it reads about 400 mpg, the ammount needed to keep the engine ticking over. This of course is not a conclusive test though because being in gear slows you down so the car may have gone further and faster out of gear, especially with the engine off - not recomennded though, you still need to steer and brake.
We came across the A66 from Penrith to Scotch corner with a following gale and apparantly used no fuel
Pleased as I was by the figures, we used to get 50-55 mpg on the same journey from the XM estate, which is bigger and heavier the the 406 which goes to show what a brilliant IDI engine the 2.1 is.
