Hi
Can some clever bod direct me to the height corrector / suspension guide in polish?
I've exhausted my patience and the best part of 90 minutes searching, reading, delving and otherwise in Superstickies, Citroen, forum.
Just can't find it anywhere!
Help appreciated.
Polish Height Corrector Guide - Where is it?
Rhothgar
- (Donor 2026)
- x 225
Clogzz
- x 40
Rhothgar
- (Donor 2026)
- x 225
Rhothgar
- (Donor 2026)
- x 225
Clogzz
- x 40
If you have Gmail you should be able to download from this link:
https://docs.google.com/viewer?a=v&pid= ... x&hl=en_US
If you don’t have Gmail, you can book in on the spot:
http://mail.google.com/mail/signup
It’s a .pdf from Tramontana of Hungary in English that I can’t find on the net anymore.
Rhothgar
- (Donor 2026)
- x 225
Tramontana rings a bell!
That's for the investigative work.
Just setting up rear suspension at the moment. Had it running at 400 mm. from floor to underside of box section (that supports boot floor) behind the sphere.
I think it needs to be about 420 mm.
284 mm. to centreline of wheel measured from garage ramp to centre of wheel bearing cap + 136 mm.
Car was running about 440 mm. so I need to find the medium now and quickly adjust the front suspension too!
Rhothgar
- (Donor 2026)
- x 225
Tried downloading the document but it states I haven't got permission to view it!
Also, just adjusted the rear height up slightly to 415mm. and the front has dropped back down by itself.
I am assuming that this is normal behaviour for the suspension. If you heighten one end, the other lowers and vice versa.
Am I correct in this assumption?
Front is running at 160 mm. now from garage ramp to underside of front cross member.
All, by the way, on a 1.9TD SX Xantia S1 for the avoidance of doubt.
Clogzz
- x 40
Rhothgar
- (Donor 2026)
- x 225
