My mot tester has used his "corrosion assessment tool" to good effect and poked a hole in the sill just under the front end of the driver's door.
Hopefully I will not have to do anything too drastic, and manufacture a patch for Les along the street to weld on with his MIG.
In the interests of finding out a bit about the process I found this site which looks a good resource for all things to do with welding and a good forum.
mig-welding.co.uk
I unfortunately read the health and safety info and the prospect of "welding arc eye", "metal vapour", "welding shivers", "toxic fumes" and "UV light and molten metal" means that I'll probably just let Les get on with it from a safe distance
Welding
- x 1209
- x 71
If you have a sense of COMMON Sense and know a little theres no problem what so ever... Id never Mig welded before, then when BOTH my XM V6's needed welding on the ends f the cills I bought a 150amp GAS Mig welder.. and done them both to no effect to me.. apart from pleasure!
I now need to do my 2.1 SED's cills, both in bad ways... to be done
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 93
- x 1209
- x 4
- x 71
- x 93
citroenxm wrote:If your sensible and take your time and DO NOT do too much at once, then it doesn't get too hot...
Paul
nahhh no fun in that
but i do usualy thoughraly check whats on the other side of what im welding,
you know the usual make sure the petrol tank is close enough
its also that skin of sound deadening citroen stick all across the underside, as that goes up quite well,
regards malcolm
- x 6899
- x 93
- x 6
- x 93
- x 138
Look at the rust in there even with hot sprayed zinc coating
They will all be like that inside lest they have been waxed.
It is the crimp at the bottom of sill that forms a double skin.........always deadly as a moisture trap.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 6899
This is the plan
Here is a piece of 1.0mm or thereabouts mild steel covered in a reasonable quantity of surface rust but whch does brighten up nicely. At £0 from my local agricultural engineers to me its perfect for the job
At the front end of the hole that needs filling up with new metal is the bolted on wing. My thoughts are to cut out two end-pieces as per the yellow card out of the steel so that the new outer sill patch can weld up to this new metal and avoid welding it to the bottom end of the wing.
I take it that trying to mimic the folded over bit of the original at the bottom edge is unnecessary and the bottom edge should just be butted up against the inner sill and seam welded.
The tne outer sill shaped bit is probably going to challenge my fabrication skills and ingenuity as my metalworking tools consist of a hammer, a couple of meaty cold chisels, and angle grinder, some ancient tinsnips and a hacksaw. A bench vice is lacking but probably would be useful.
Maybe all thats need when I get started is a strong pair of hands and form it over the edge of the kitchen table
regards
regards
