I have a Mk1 C5 and the passenger headlight has yellowed. I have tried cleanin the outer but it remains cloudy. I am therefore in the middle of purchasing a replacement lamp.
Being non-techy, my question relates to removal and fitting. Is this any easy task? Any advice gratefully received
C5 HEADLAMP
- x 1056
StevieOMG
BX
- x 19
StevieOMG
john alexander
dnsey
- x 19
- x 5652
Excellent advice.dnsey wrote:When you replace the unit, make sure that the bulbs are the UV filtered type, as excessive UV might have been the cause of the yellowing.
Mine are yellowed and pitted, spent ages trying to buff them up but it also appears they have 'something' growing on the inside of the glass
cachaciero
- x 9
Do NOT ever use cutting compound or any abrasive polish on "good glass", (well plastic). My understanding is that the basic plastic moulding is polycarbonate (Lexan) coated with another transparent compound which filters out UV.
Abrasive polishes remove this filter and over time polycarbonate will yellow when exposed to UV.
Off course if you have already got to the yellow state then polish it with that you like but it will make no difference as the yellowing goes right through the thickness of the plastic.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
StevieOMG
Fitted a new headlamp unit this morning. Despite reservations, I part removed the bumper (from the nearside where I was replacing the lamp). Bumper removal was easy - not so with the headlamp. The two lower bolts were easy, the top bolt was not and I had to hacksaw it off and replace with a new bolt. Made sure bulbs were functioning before putting it all back together. What a difference. You can now tell when the lights are on. Thanks for all the advice.
- x 5652
They were well pitted and looked as though they had been 'oversprayed' on the upper part mainly but on closer examination all over.cachaciero wrote:Do NOT ever use cutting compound or any abrasive polish on "good glass", (well plastic). My understanding is that the basic plastic moulding is polycarbonate (Lexan) coated with another transparent compound which filters out UV.
cachaciero
Buffing did improve it but not significantly.
I wonder if mine are yellowed due to my habit of always having dipped headlights on?
Only did the buffing recently and they were already significantly degraded.
Bumper came off and lights came out easily when I had to replace a lost bulb clip.
cachaciero
- x 9
Steve I doubt that normal use would cause the yellowing, bear in mind that the same lense cover is used with HID's that's an assumption on my part but they look to be identical. Normal filament lamps don't have any significant UV in their spectrum, lots of Infra Red though.myglaren wrote: They were well pitted and looked as though they had been 'oversprayed' on the upper part mainly but on closer examination all over.
I would put it down to the coating having been polished away before you got the car (dealers are good at extreme polishing of cars !) and normal daylight UV of which there is a lot these days doing the rest
Some chemicals probably don't help either I know that normal thinners used as a cleaner will accelerate yellowing and crazing of acrylic / perspex, don't know about Lexan though.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
