Hi All
Ive got a concern, Ive got a car, Petrol injection, however, the altinator is only giving out 13 to 13.1 volts out through the whole rev range..
The Battery light shows then when started goes out completely.
Ive got a bit of a journey to do, will I be safe, or not?
What sign is it giving tell me Ive only got 13v - Or is the altinator totaly buggered already?
Paul
Altinator Only giving 13 VOLTS
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
mongoose100
13.1 is a fully charged battery. 13.8 and above should be what you're aiming for when the alternator is charging correctly.
The brushes may be worn or stuck, try tapping alternator with something solid - this sometimes helps if the brushes have stuck
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
2001 Citroën C5 V6
dnsey
- x 19
HDI
- x 7
Brushes or regulator. Both can be replaced easily and cheaply but the alternator will have to come off to do it.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
BX
- x 19
Beware of jumping to conclusions. If the battery / no-charge light goes out as soon as the car is started there is a good possibility that the alternator is ok. What you need is an ammeter along with the voltmeter. If the alternator is pumping several amps into the battery but the battery voltage is not rising to over 14V there is a good chance that it is the battery that is on the way out. It may be starting ok now but some day soon!!!. Either check the charging current as well as the voltage or swap out the battery with a known good one before spending money on an alternator.
imperial21
- x 8462
- x 1061
