Hi guys,
Problem here is that when I drive my car (C5 2.0L HDI LX) after some time It smells as something is burning. My clutch also works almost halfway (works fine though). So what this can be? weak/burning clutch or something else?
If clutch, then how long it normally lasts after it starts smelling?
Finally, how much roughly will it cost me for the repair/ new clutch?
Help with clutch. . . burning smell?
g_feb
Citroen C5 2.0L HDI LX Reg:02 Hatchback
76,660 Miles
76,660 Miles
miked
- x 6
Re: Help with clutch. . . burning smell?
Can you expand on your description above, it might help us understand the problem.g_feb wrote:It smells as something is burning. My clutch also works almost halfway (works fine though).
Onlinemyglaren
- x 5689
g_feb
Thanks for the reply.
When I drive my car and try to push it a little bit, even to 50, I start feeling a burning smell from the car. It drives fine though. No prob at all. My clutch works fine but it is bit high in its position, that is why I was thinking about clutch as I have heard that clutch starts burning and smells when it goes weak.
what are binding brakes and how to check binding brakes (front , rear and hand brake)?
76,660 Miles
76,660 Miles
wright
Citroenmad
- x 110
A clutch should only smeel when its being heated up, so when the clutch is slipping. Some people who have th epoor habit of holding the bite at junctions often report this and wonder what it is
The brakes will smell of buring if they rub, I have had this on one of mine. The handbrake works on the front of the C5, the handbrake levers on the calipers stick and keep the handbrake on slightly. This does cause a wheel wobble at speed though, usually anyway.
If it is the clutch then it must be slipping in order for it to get hot and smell of burning. Is there a rise in revs when you aaccelerate without the car accelerating with the revs?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
rabenson
I'm with myglaren on this one - does your handbrake have about an inch of slack when you start to pull it up?myglaren wrote:Check for binding brakes - especially the front. Handbrake is known to stick on them.
Mind you don't burn your hands on the discs, they get very hot.
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
