2005 C5 air filter - where is it?
flipside
Unread post by flipside »
I'm planning to change my air filter and pollen filter. From what I understand the pollen filter is on the front left side, behind the carpet with the light. Screw it out and replace it.
However I can't find any threads about the air filter? My C5 has air conditioning, I don't know if that makes a difference or if the filter is the same. I plan to get the actual filters at the Citröen dealer and then replace them myself.
Anyway, where is the "cabin" filter located? Do I access it from inside the car like the pollen filter, or is it in the motor compartment?
Thanks!
AndersDK
Unread post by AndersDK »
Item 6 is the click to open end lid for the filter. You can see the retaining hook on the lid.
The lid is located in a straight line above the figure "72" on the drawing.
Item 5 is the filter itself.
Anders (DK) - '90 BX16Image
flipside
Thanks! :)
Should I just go for the filters from the Citröen dealer, or do you recommend any others?
AndersDK
flipside wrote:Thanks! :)
That is for you to decide 8-)
Its somewhat religious IMHO :D
x 5688
Mine are all MANN filters - it's no use giving you the part numbers as yours will be different to mine but I get them from a friendly local spares and accessories shop.
Pollen filter was £20 and air filter £12.
yeomills
Unread post by yeomills »
Euorocar parts list two at about £13.00
