Hi all,
2000 Xantia V6, running non-hydraspastic corners.
When hitting speed bumps etc, the compression is fine however coming down off such things results in a decent thud from the fronts - almost like the suspension cant rebound fast enough. The rear seems more than happy
Could this be caused by centre sphere being flat maybe?
Cheers in advance
Hard Rebound
mongoose100
Hard Rebound
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
2001 Citroën C5 V6
- x 1484
- x 8462
Yes, I would entirely agree on all counts. My experience of running a V6 on non-Hydractive spheres is that the damping is well below par.
Try, for now, running in sport mode and see if that improves matters. It will be worth running a Lexia or ELIT across your Hydractive ECU to check it's clear of faults and that all sensors are working. It may not be switching to hard mode promptly under braking.
- x 8462
mongoose100
mongoose100
Sport makes no noticeable difference to the thud - however, it does firm things up quite nicely in corners ets. My view is that it is super sensitive in relation to switching to hard tooCitroJim wrote:Try, for now, running in sport mode and see if that improves matters. It will be worth running a Lexia or ELIT across your Hydractive ECU to check it's clear of faults and that all sensors are working. It may not be switching to hard mode promptly under braking.
Lexia shows no faults in Hydractive ECU.
braking shows no signs of nosediving etc.
Curious tho, how would 1.9TD Hydractive spheres feel like???
Regan.
2001 Citroën C5 V6
2001 Citroën C5 V6
- x 8462
Hydractive 1.9TD spheres should be absolutely fine... I'm not aware of a special V6 fitment..
Ride height adjustment is not such a bad job as long as you can do it on a ramp, have all four wheels under load and the car level...
Do ecxclude everything else though before playing with ride height...
mongoose100
- x 8462
No, as the car should switch to hard on braking/deceleration and this will isolate the centre sphere. Damping in my experience is strictly in the province of the corner spheres and the centre sphere is there only for comfort!mongoose100 wrote:Cheers Jim.
So, assuming centres have nothing to do with this issue?
Johnny Cogs
OOOoooo ekkk, I think I have made a booboo.... I had to get my hands on some spheres quick and have grabbed a pair of fronts from a 2001 1.8 petrol model.
Xant, (i know I should buy knew but wasn't an option at the time) to put on my '95 td VSX estate....
Am I now reading correctly that spheres are differently weighted/preassurised and I am replacing a broken spade with a spoon???
- x 8462
Yes, spheres have different pressures/damping rates depending on their intended application.Johnny Cogs wrote: Am I now reading correctly that spheres are differently weighted/preassurised and I am replacing a broken spade with a spoon???
Corner (i.e. suspension) spheres all have dampers but the rates differ significantly between fronts and backs. You should never put front corners on the rear corners and vice versa. Likewise Hydractive spheres should not be fitted to a non-hydractive car although vice-versa it can give a slightly softer ride but a bit under-damped.
Accumulator and hydractive centre spheres have no dampers and must NEVER be used on corners. Likewise, corner spheres with dampers must never be used as accumulators or hydractive centre spheres.
Generally, front and rear corners can be experimented with (within the bounds of the above) to see what suits you best. For instance front corners from a 1.8 petrol may give you a subjectively better ride on say, a 1.9TD. Likewise rear corners intended for an estate may give what you may consider a better ride on a hatch or vice-versa.
Providing you obey the fundamental rules as stated above, it can be interesting to experiment with spheres.
Johnny Cogs
- x 8462
mongoose100
Well, tackled the front ride height today, not such a bad job
Some idiot had set the front height via the manual control rod, released that and the car went sky high! Anyway, back to spec and comfort and rebound back to Citroen levels!!!
Now, just need to find out why passenger mirror drops in reverse and doesnt return... Pain in the butt
Regan.
2001 Citroën C5 V6
2001 Citroën C5 V6
