Engine Bay Undertray
Penguin
Chaps, a couple of weeks ago I was driving home and all of a sudden I heard a horrendous noise coming from underneath my car. I pulled over to find the engine bay undertray (does it have a better name?) dragging on the floor as the rear bolts had gone missing. I undid the front bolts and removed the tray. It was pretty oily so I left it in the hedge until I could get some plastic sheeting and then I could go pick it up. Following morning I went to get it only to find the usually innefficient council had suddenly discovered efficiency and removed it. I would like to fit another but my question is...... Are all the trays the same? i.e. would a tray from a petrol model and/or a series 2 fit? Or do I need to get one made specifically for a series 1 1.9TD?
Ta.
Ta.
95 Xantia 1.9td SX
HDI
- x 7
I've used a TD type on my HDI. Doesn't fit exactly, it touches the lower intercooler pipe, but it didn't seem to be a problem.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
stedmancinques
Chris570
- x 36
Hmmm i don't buy that sorry. My HDi doesnt leak oil at all. sounds a bit like an urban mythstedmancinques wrote:Only the diesels have the undertray; I was given to understand that it was because they couldn't get them to stop leaking oil, so the undertray disguised the fact until it was safely out of warranty..
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
HDI
- x 7
Most certainly an urban myth. The most likely reasons are, air control for aerodynamics and engine temperature, and, noise suppression.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
mongoose100
stedmancinques
xmexclusive
On XM diesels the recommendation is to remove and junk the undertray.
Due to a foam edging strip they trap moisture and salt water against the bottom of the front subframe. Quite a few XM MOT failures from rusted through bottom plates. No rust treatment on XM subframes just thin black paint. Would expect other Citroens to be similar.
Nasty catch 22 here as well that I got caught on a couple of years ago.
MOT tester fails the car on subframe rust, declares that the subframe it is a suspension component. Warns that weld repair of suspension components is not permitted and that he must fail the car if it is returned newly welded.
John
John
Xmexclusive
Penguin
Well, thanks for all the replies. My TD definitely leaks quite a bit of oil (the main reason I want to replace the tray!) and the tray dissperses it around the countryside far better than it does now! My drive has started to resemble a dalmation. I guess its on the blower to all the scrappys in the area and see if they've got one.
95 Xantia 1.9td SX
Onlinemyglaren
- x 5668
Mine came off on Saturday.
The Antipollution fault had disappeared last Thursday but has now returned and I am wondering if there is a connection.
I hadn't refitted mine very well, a lack of nuts 'n bolts and places to nut'nbolt them to.
Job for the weekend
The leak thing I agree must be a UM - mine leaks not in the slightest - except when I am clumsy with refilling after a service there is no oil on the engine or under it at all. No top-ups between services either.
Never had any leaks on the TD either.
Job for the weekend
- x 8334
I don't think the V6 ever had one...mongoose100 wrote: but V6 (MKII) doesn't
I find this a bit odd about the oil leaks... All PSA engines (diesel included) seem reasonably oil-tight if properly maintained.. Most oil seems to escape out of the turbo pipes..
It was expounded on here a while back that one reason* diesels have the tray in order to keep the oil in the sump at a nice temperature. Word was that if the tray is discarded then the oil can run a bit cool.
This is not a problem on the V6 and in this respect it needs all the oil cooling help it can get. An undertray would fry it...
* Other reasons were those of aerodynamics and sound deadening.
Onlinedeuchebleu
- x 21
mongoose100
Do the 6's get rather hot in the oil department? Do they have a cooler?CitroJim wrote:I don't think the V6 ever had one...mongoose100 wrote: but V6 (MKII) doesn't
Was contemplating putting one on at some stage too, doing a fair bit of towing around NZ's hilly terrain!
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
2001 Citroën C5 V6
Xaccers
- x 188
You could always take out a second mortgage and treat yourself to a brand new one
DIY sphere tool
DIY sphere tool
- x 8334
Yes, they do as soon as the mercury hits a reasonable figure and you are pushing on a bit...mongoose100 wrote:[Do the 6's get rather hot in the oil department? Do they have a cooler?
In an S2 V6 you're oblivious to it as there's no oil temperature gauge, it's place being taken by the gear position repeater. The S1 V6 has an oil temperature gauge and it's a bit of a frightener really...
Maybe that's why they deleted on the S2....
There is no coller fitted as standard but I reckon one wouldn't come amiss in warmer climes...
