V6 S2 Cutting out when engine cold
x 8406
Chris570 wrote: took me 4 minutes Jim, dunno what the problem is
Must be me, I must be loosing it :roll: After all, it took me all day yesterday and part of today to service the V6, take off the HP pump, alternator and AC Compressor, reseal the pump, clean up the alternator, install new flexi hoses and put it all back together..
I reckon you would have had all that lot done in say, a couple of hours?
:lol: :lol: :lol: :lol: :lol:
Chris570
x 36
Unread post by Chris570 »
well if i were taking a long break in the middle 8-)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
f00lzz
Unread post by f00lzz »
DHallworth wrote:Andrew,
The one I'm referring to is only accessible from the top unless you've got arms like Mr. Tickle!
Flooz, I believe it's the sensor in picture 2. If you can get a clearer picture of that I'll be able to explain better.
Look under the Lexia locations thread, there might be a member near you with a Lexia who can confirm which sensor it is!
David.
I see that Chris56000 is only about a mile from my house (how come I didn't know that!!) I am going to change the temp. sensor adjacent to the airbox tomorrow and if it still plays up I may get in touch with Chris56000.
Cheers for your guidance Gentlemen
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
x 5673
David.
The pushpins on the map are deliberately vague - don't imagine that that is exactly where Chris is located.
f00lzz
All.
It would seem that there are three temp. sensors in the area that David is referring to. Would a Lexia be able to identify which sensor or just identify a temp sensor fault? I obtained the info. off Citroen Service AC
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
x 8406
Yes,
Green is the ECU temperature sensor, Brown is the Bitron for fans and A/C and blue is the coolant over-temperature warning light sender..
Only the green one is relevant in this context...
f00lzz
Thanks Jim..
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
f00lzz
I now have the sensor and will do the job tomorrow, thunderstorms permitting. For future ref.
GSFNo.
ZSMISC
Part No.
55519
Total Cost
£13.66
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
DHallworth
x 167
Unread post by DHallworth »
Hi Flooz,
When I did ours I just took the pipe work off the airbox, lifted the airbox straight out, got an open ended spanner on the sensor, cracked it, unscrewed it by hand and changed it.
Took around 10 - 15 mins at most from start to finish.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
f00lzz
Hi All.
Swapped out the sensor... must be the easiest one to do on the V6, I hope it cures the problem.
http://s69.photobucket.com/albums/i65/z ... %20Sensor/
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
lexi
x 133
Unread post by lexi »
Nice work and research. I might put one on. I have a hesitation........ ie semi stall when cold on brisk take off. Fine when warmed up.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
f00lzz
lexi wrote:.. ie semi stall when cold on brisk take off. Fine when warmed up.
Yep sounds similar to mine... sometimes could just keep it going, othertimes would cut completely.. difficult to dip the clutch and give it a rev on an automatic :)
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
f00lzz
Thank you all for your advice and guidance. I am pleased to report a smooth and uneventful trip to work this morning.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
DHallworth
x 167
Just seen this now.
Glad to see it seems to have cured the problem.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
