Brake Spring mod
x 1485
It's only fitted on RHD Xantias AFAIK - LHD variants do without!
I've driven close on 200k in Xantias since Oct 2002 and had no real trouble with the brakes. Maybe I'll try 'the mod' and see!
andmcit
x 30
Unread post by andmcit »
LHD v's RHD:
Item 3 on the RHD is the villain of the piece.
Nothing moves you like a Citroën
x 94
Unread post by citronut »
and the spring in question is indside No. 3 and not the spring No. 5 in the drawing
regards malcolm
Toby_HDi
x 3
Unread post by Toby_HDi »
Do you just pull the pedal up and pop it out? Or is it more involved?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Deanxm
x 87
Unread post by Deanxm »
yes, unclip the pedal switch plug to allow the pedal to swing further back towards you and lever the assembly number 3 in the parts diagram out with a screwdriver carefully.
Once in your hand you will see how it comes apart to get the spring out Toby
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
