Turbo whine on C5
citrokid
Turbo whine on C5
Unread post by citrokid »
noticed that the turbo on 1.6 C5 hdi has a whine (not much) when at about 2500 rpm.
What is this an indication of ??
x 8343
If it's boosting properly, running well, the whine is just audible and does not sound 'nasty' or rough, nothing very much normally. Some can be audible like this and I well recall my Turbo Metro of many a long year back making quite a satisfying turbo whine...
It may be worth an oil change if the oil is on the elderly side.
A whistle, rather than a whine, indicates a boost leak...
citrokid
CitroJim wrote:If it's boosting properly, running well, the whine is just audible and does not sound 'nasty' or rough, nothing very much normally. Some can be audible like this and I well recall my Turbo Metro of many a long year back making quite a satisfying turbo whine...
Oil changed today !! have not driven the car other that a few miles - no change
it is working well, no change in car performance, the whine sounds like a siren many many miles a way, almost faint. I wonder is my whine the same as a boost leak?
if so where is the most likely location of the leak?
Deanxm
x 87
Unread post by Deanxm »
whine is usualy because of a poorly ballanced turbo charger but then some turbo's do make noise and some as Jim says do not, if you do have a boost leak though it may be worth checking over all the boost pipes to make sure they are securely fastened first and nothing has chaffed through them.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
citrokid
Deanxm wrote:whine is usualy because of a poorly ballanced turbo charger but then some turbo's do make noise and some as Jim says do not, if you do have a boost leak though it may be worth checking over all the boost pipes to make sure they are securely fastened first and nothing has chaffed through them.
D
i will check over all the pipes tomorrow,
would a turbo go from being a quite unit to a noisy unit over a few weeks /months
Deanxm
x 87
i dont think so no, centrifugal force would ensure any oil or carbon on either the compressor or turbine wheels was distributed evenly so it would not become unballanced in use.
Have you noticed a lack of power or economy at all recently?
D
XM Prestige PRV6 92
Chlorate
Unread post by Chlorate »
The engineer within me screams a little whenever centrifugal force is mentioned :D
But you're right, they spin at around 150,000 RPM so crud on them wouldn't settle in a way that could put the turbo out of balance over use. Although if something could make its way past the air filter somehow, it could do a fair bit of damage to the compressor.
However since the bearings are hydrodynamic bearings they do get a bit fussy if the engine's lubricant is ignored for any length of time, or if you don't let the engine idle for a bit before turning it off.
If the power or economy hasn't suffered though, it's probably not something to worry about.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
dnsey
x 19
Unread post by dnsey »
My C5 turbo also sounds exactly like a distant emergency siren at times, and has caught me out on a couple of occasions, looking for the blue lights!
I'd say it's perfectly normal, and nothing to worry about.
fynnbar
Unread post by fynnbar »
It is, however, a sign that the turbo bearings are wearing, and it will get steadily worse.
Mine has been doing so for about 2 years, and I now think it's time to replace it.
2004 Dispatch 110 HDi
citrokid
fynnbar wrote:It is, however, a sign that the turbo bearings are wearing, and it will get steadily worse.
Deam xm - No noticable loss in power and mpg is good .
fynnbar how many miles is 2 years - i do about 20- 25K p.a.
fynnbar
20-25K in two years. Don't travel as far as you ...
citrokid
fynnbar wrote:20-25K in two years. Don't travel as far as you ...
thanks for the info
