Fan Relays Behind Grille
KennyW
x 165
Unread post by KennyW »
When I had a problem with my fans it turned out to be a bad connection prior to the fans in the wring loom.
The only way to cure it was to remove the front grill,lights & bumper to access the wiring and slowly check back until I found the fault :).
With the dry Easter weather an opportunity :wink:
Kenny
C3 1.4 petrol (SWMBO)
MikeT
x 232
Unread post by MikeT »
KennyW wrote:When I had a problem with my fans it turned out to be a bad connection prior to the fans in the wring loom.
Kenny
Exactly the same with mine. It was a corroded (completely disintegrated) splice in the loom within the O/S wing, diagnosed by testing each relay feed in the radiator grill then traced back (thanks Toby!) using wire numbers.
Clogzz
x 40
Unread post by Clogzz »
My fuse box
While you’re in the fuse box, check for an open 5A fuse that’s meant to actuate the top right relay.
If the fuse is good, then check the wires and connectors as posted about since.
Does the relay click when you turn on the aircon ?
That’s where the fault is because ‘manually’ closing the relay starts the fans.
P616VKX
Unread post by P616VKX »
The Air Conditioner works fine, actually, it works really well! All I need is a new pollen filter, but that's neither here nor' there.
I hear a click when the Air Con is turned on, but that MIGHT be the compressor kicking in.
The Relays on the radiator do not click when the AC is switched.
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
Clogzz
x 40
The top right relay must click on almost immediately when the aircon is switched on.
The compressor will loudly clutch in about two seconds later.
P616VKX
It doesn't click when the AC is applied.
Stuart.
P616VKX
When I'm in Cornwall on holiday, I'm going to try swapping the Bitron relay for a new one. It's one of the last things I can think of causing this problem... :(
x 8417
P616VKX wrote:When I'm in Cornwall on holiday, I'm going to try swapping the Bitron relay for a new one. It's one of the last things I can think of causing this problem... :(
Definitely a holiday job that :twisted: Bumper off and inner panel too. Lovely job but infinitely more fun that whiling away your time soaking up the sun on the beach... Ham and sand sandwich anyone?
P616VKX
The Bitron Relay is in the fusebox under the bonnet... Lol.
x 8417
P616VKX wrote:The Bitron Relay is in the fusebox under the bonnet... Lol.
No it's not :( It lives under the plastic panel under the passengers headlight... It is a ****** to get to :twisted:
P616VKX
Well, the relay that I played with resulting in working fans for a short time was a purple one under the fusebox cover marked "BITRON"...
That's my next port of call, whilst I'm down in Cornwall.
x 8417
P616VKX wrote:Well, the relay that I played with resulting in working fans for a short time was a purple one under the fusebox cover marked "BITRON"...
Ahh, fair do! I was thinking of the fan controller ECU... This device is also made by Bitron... Bitron is in fact just the trade name of an auto electrics maker (like Lucas) and their name can be found on all manner of electrickery...
Safe to say that Bitron is most associated with fan and A/C control stuff though...
Enjoy Cornwall :D
P616VKX
If this doesn't work... What am I looking at? A break in the wiring? a duff plug? Or rewiring the fan relay sockets? I just don't know where to look as there's just NO room to work under the bonnet!
Clogzz
x 40
There’s still the 5A fuse to check, and if it’s good there will be a break in a thin wire.
To go any further you would need a test lamp or multimeter to check for a permanent 12V on two connectors of the top right socket.
Rewiring sockets is out of the question; it’s a monumental job and all the thick wires are good because they can spin the fans when you close the relay ‘by hand’.
P616VKX
Clogzz wrote:There’s still the 5A fuse to check, and if it’s good there will be a break in a thin wire.
All 5a fuses are fine, under the bonnet and otherwise. Removed, looked at, replaced. All good... I don't even know which 5a fuse I'm meant to be looking at but they're all fine under the bonnet and in the cabin.
Stuart.
