306 HDi Won't Start
DHallworth
- x 163
306 HDi Won't Start
Guys,
Having a spot of bother with a 306 HDi and need your advice...
The car was running ok on Wednesday, started ok, was driving ok, etc but the cabin heater stopped working when my brother was out in it.
He tried to start it tonight and it's turning over no problem at all. However it just won't fire.
I've had it on Peugeot Planet this evening and it's showing that it's unable to communicate with the engine management ECU and the BSI is showing a fault code for no communication with the engine management ECU.
I've noticed that you can hear the heater running very quietly for around 30 seconds before it shuts down too.
I've cleaned the multi plug on the ECU and reseated it to no avail.
Anyone got any ideas?
Ta in advance!
David.
Ta in advance!
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
AndersDK
The Birdman
Try and reconfigure the engine ecu
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
DHallworth
- x 163
I can't do anything with the engine management ECU as the diagnostics machine can't even locate the ECU.
Does anyone have a wiring diagram for the 306 HDI?
Checked all the fuses too, none blown. Removed them all and reseated them to no avail.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8191
David, if the Lexia can't see the ECU then this suggests the immobiliser has not done its job or there is a voltage supply missing to either the ECU or the immobiliser transponder.
This is exactly the same symptom as happens on MKII Xantias when a wire in the loom that runs across under the rad gives up and deprives something of critical volts...
I can imagine there could be a similar troublesome loom in the 306...
Another thing worth checking will be the double injection relay...
Do you have any indication on the dash to indicate if the immobiliser failed to deactivate on ignition on? The RFID chip in the key could have died or the aerial around the ignition switch may be duff or simply misplaced and therefore unable to read the key chip...
dieselnutjob
DHallworth
- x 163
I've been looking at this again this morning and the Lexia can now interrogate the ECU without any problems.
However there weren't any interesting fault codes stored on the ECU.
There's a great flow of Diesel to the fuel filter so I decided to check the flow of fuel to the injectors...
I cracked an injector on the car today and tried cranking it and got a measly spurt of Diesel from it. I did the same on the 406 HDi we've got and got a right jet of Diesel from it.
This leads me to believe that it's the high pressure Diesel pump that's probably at fault.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
- x 163
Toby_HDi
- x 3
Can you hear the lift pump in the tank priming when you switch the ignition on?
The HP pump won't kick in until a specific fuel pressure is reached. This is provided by the LP lift pump in the tank.
They are one of the more common HDi foibles.
As for a wiring diagram, which bit of the system are you after? What year is said 306?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
DHallworth
- x 163
Deanxm
- x 87
David
If the injectors are not firing correctly then the rail sensor is not seing enough pressure, either because there actualy isnt enough pressure or because or a duff sensor. have you tried swapping the rail pressure sensor? or regulator?
I found this when helping a friend on a 306 HDI, it would fire the injectors but only wiith enough voltage to make a noid light faintly flicker, its like the more pressure there is the more voltage the injectors recieve when cranking.
As Toby says is the lift pump working at about 1bar and are the pickup filters clear?
Did you resolve the no dialogue issue with the ecu? that does sound like some power has gone missing.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 1456
As above, check the live data on the Lexia when cranking. If you are not seeing 120 bar on the rail then it will never start - the ECU won't start injection till it sees 120bar. No idea how you can check they're working though... It also needs to see and make sense of the cam timing before it will fire - but I'd have thought this would flag a fault if it was AWOL, but again worth a check on live data.
DHallworth
- x 163
Well we gave up on the car on Tuesday night as it just wouldn't start and the ECU wasn't responding.
We towed it to the dealer, they've done diagnostics on it, checked the wiring etc, and they've diagnosed the ECU faulty. We've been using them for 5 years and I trust their judgement. They're not the usual Mickey Mouse dealers.
If I buy a salvage 306 HDi, can I take the ECU and the transponder from the key and put them into my brothers car? Or can you unlock any HDi ECU?
Thanks!
David.
Thanks!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1046
Yes but you would also need the BSI aswell though as the ECU, BSI & transponder key are all matched together. Remember if the salvage car has a higher milage then your brothers car will permanantly inherit that from the 'new' BSI. Remember if you go down this route to keep a note of the chassis & reg numbers of the donor car incase you need the confidential code to progam new keys etc in the future.DHallworth wrote:If I buy a salvage 306 HDi, can I take the ECU and the transponder from the key and put them into my brothers car? Or can you unlock any HDi ECU?
As far as unlocking the ECU goes it can't be done with Lexia/Planet but there are people out there that can do it by reflashing eproms inside the ECU's.
DHallworth
- x 163
Any 306 HDi will have a higher mileage then this one as it's only done 55k miles.
There's a guy 15 miles from us who does digital mileage correction so that might be worth a look into as well.
Be handy to find an unlocked ECU though.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
