Xantia 2.0 HDi s reg 1998
The ABS light on the dashboard has recentley come on and stays on constantly, is this a common fault that can be easily fixed or does it need plugging into the expensive box?
Also anyone confirm whether reversing lights are compulsary to pass an MOT.
Thanks, Will
Xantia ABS light?
HDI Dave
- x 3
Yes mate,common problem apparently.
Mine has been on for 2 years
Not too expensive if you can diy,think the sensor's around 12 - 15 quid on ebay...
IIRC, you can check it with a normal cheapo multimeter, up at the ABS ECU jobby..I can't remember the reading..1200 ohms or summat? Anyway, mine showed zero, on the front offside, the most common failing one I believe.
Might get away with cleaning/reseating the sensor, in case there's any crud in it also..
Excellent thread by red_dwarfers with pictures shows absolutely everything, mk 1 and 2...here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=26012
I think you need the abs light working for the mot, depends on your tester though
Reverse light I'm not sure, I don't think they're compulsory, but don't quote me on that, there's a dvla mot webpage somewhere..
1999 Xantia LX 2.0 HDI 110 Rusteration project...
- x 5672
