Citroen C3
allanmc
Citroen C3
Unread post by allanmc »
My son has a Citroen C3 with a steering problem when he comes to a stop if he takes his hand off of the steering wheel it goes to full offside lock can anyone help please.
allan
spider
x 77
Unread post by spider »
Are these hydraulic or electric power steering ?
By electric I mean an assistance motor on the column not a motor / pump assembly as per Saxo / 106 arrangement.
I'd have to assume its an assisted column, although I've never heard of this happening and similar systems are fitted on a lot of different marques (Fiat + Small Vauxhalls amongst others) , it will probably be a problem with the motor / torque sensor on the column I expect, I think it comes as an (expensive) assembly.
It obviously needs sorting asap as it sounds quite dangerous to me...
Andy.
x 1056
Unread post by wheeler »
its an assistance motor type but the motor & torque sensor are part of the steering rack rather than the column. There is also a seperate ECU for the steering aswell.
