C5 8v HDI 2004 gearbox
howiedean
Unread post by howiedean »
Hi,
I'm looking to change the gearbox oil on my c5 HDI. I can't find the filling hole on the gearbox. The gearbox does not look like the MLT5 one and I have no idea where to look. Does anyone have a photo of the filling point?
Regards,
Howie
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
wright
Unread post by wright »
i filled my one through the reverse light switch hole on top of the gear box, it only needs 1.8 litres of 75w80
02 C5 2.0 hdi 110
x 1955
On the ML5C gearbox (reverse over on the left next to 1st gear) I was shown the filler on my C5 while it was on a set of car ramps. It was on the side of the box facing the bulkhead.
A bugger of a place to get to - fortunately mine didn't need topping up.
If I were doing a complete oil change I think I would measure how much oil came out and then replace at least that amount through the oil breather or something else that was on the top of the box.
wright
according to autodata the 04 c5 2.0 hdi takes 1.8 litres of 75w80, i put in 2 litres and it blew a drop out the breather, it will get rid of any excess oil
02 C5 2.0 hdi 110
howiedean
wright wrote:according to autodata the 04 c5 2.0 hdi takes 1.8 litres of 75w80, i put in 2 litres and it blew a drop out the breather, it will get rid of any excess oil
Thanks everyone, I'm still struggling to work out where the bl*&dy filling point is though.
Howie
wright
on the top of the gearbox there is the reverse light switch disconnect it and take it out and the oil can go in there
02 C5 2.0 hdi 110
fynnbar
Unread post by fynnbar »
The filler is on the back of the diff housing, about level with the driveshaft.
2004 Dispatch 110 HDi
c.morewood
x 55
Unread post by c.morewood »
Here I think.
I believe its the same gearbox as the late Xantias
I used the funnel and tube method, using the filling tube from the gearbox oil bottle taped to the end of a 1m plastic tube which was then taped to a funnel with gaffa tape. You have to have the car on a level surface though.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
howiedean
c.morewood wrote:Here I think.
Thanks everyone, will have a look at changing the oil as I have a couple of options when I get chance.
Regards,
Howie
Howie
howiedean
Regards,
Howie
All done now. I could not find the filling point at the back of the gearbox, so used the breather hole on the top.
Regards,
Howie
Howie
x 1955
howiedean wrote:All done now. I could not find the filling point at the back of the gearbox, so used the breather hole on the top.
What I said!
