2 quickies chaps - wipers + central locking
HDI Dave
x 3
Unread post by HDI Dave »
Windscreen wipers are fine on all settings except normal wiper mode, ie, fine on intermittent or double speed,just don't work properly when you want constant/normal wiper operation..typical :wink:
Not a big issue for me,(well, it's a bit of a p.i.t.a) but the wife can't suss it. So I'll have to sort it.
If you push the wiper stalk left,towards the steering wheel,it seems to work ok.
Now then, could I take it off and clean the contacts etc, or is it buggered?
Central locking:
Sometimes the locking's being a pain. If I press the fob, (which would normally go 'blip',lock,flash indicators),locked.
it goes blip..bloop,locks and unlocks again.
Haha,sorry, it's the only way I can describe it :lol:
It's not a seatbelt stuck in the door sound,it's different.
I then have to mess with the key,till it locks.
I have noticed the drivers door card has come away a bit,coincidence?
Any ideas welcome : )
1999 Xantia LX 2.0 HDI 110 Rusteration project...
dave2011
Unread post by dave2011 »
sounds like the stalk needs replacing........ :) as for the central locking are you sure the doors are shut right coz my synergie locks n unlocks the doors if the doors or boot aint shut right.failing that a broken wire in the door jamb. 8-) :wink:
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
If the doors are correctly shut and the central locking immediately unlocks then check the contacts where the loom block connects onto the door locks. I've had this problem a few times now and each time the culprit has been the N/S/F one for some reason. If you're near anyone with a Lexia, that can be used to tell which door lock is causing the problem.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
HDI Dave
x 3
Yes the doors/boot are all correctly shut with no obstructions.
DickieG wrote: check the contacts where the loom block connects onto the door locks.
Where will I find the loom block...in the door, or in the footwell etc? I'm struggling to find it in the Haynes manual.
Cheers, Dave.
DickieG
x 38
In the door itself, where the block connector plugs into the door lock assembly remove the doorcard to gain access.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
