I took the plunge the other day on an ebay-Lexia (upon realising I can easily get my money back later!) to diagnose an intermittent but regular "anti-pollution fault" on my C5 2.2HDi (2001). I'm aware that error basically means anything, so opted to try the Lexia as a starting point.
It's quite an existing bit of kit isn't it!
Errors absolutely everywhere, but I've managed to whittle them down to a few unexpected oddities, not at all related to the fault I was looking for:
permanent fault: Blower Open Circuit
That sounds self-explanatory except that the blower works fine, and always has. Is there some other blower whose presence I'm unaware of and whose loss I haven't missed?
permanent fault: Door mirror - deicing output Open Circuit (both sides)
Do these cars have heated wing mirrors? I wasn't aware! Is it likely that both of these would have failed after ten years?
Temporary fault: fuel filler cap sensor signal
This bothers me, but I don't seem to be able to determine when this last occurred. In the 35k miles I've had this car (since 105k miles) the fuel additive hasn't needed topping up. I was never sure if I was just lucky or if it simply wasn't being added to the fuel, and that adds to my concern. I'm not sure what the mileage interval is supposed to be, can anyone say? Also, to add to my fears, when I run the injector actuation test, I can't hear it clicking (the pump works). Is it just really quiet?
And the alarm ECU isn't contactable - but I might have bricked that at lunch time somehow
Regarding the fault I was looking for, three temporary faults:
Turbo pressure signal. Short circuit to positive or open circuit or value too high and Turbo pressure measured too high
I assume those to be the same fault, turbo over-pressure, and very likely I suppose to throw it into limp-home mode until the next journey. I'm guessing leaks in vacuum hoses around the solenoid valve is a likely culprit (or the valve) - although I'm also concerned about lack of eolys in the exhaust, blocking the fap and possibly contributing to turbo over-pressure..? I'm not sure how it's all plumbed together.
Crankshaft - camshaft synchronising. Engine speed signal variation too sudden.
That sounds a little concerning, but unless it reoccurs (i've cleared the faults tonight) I suppose might just be a one-off 'blip'?
Fascinating stuff this. There's so many data points the ECU keeps track of (I guess, some measured, some calculated) I'll be here for weeks studying them all
