Friend has a 59 plate C5 HDI. The problem is a leaking clutch cylinder which leaks fluid onto the clutch obviously causing slip.
He's been quoted £1200 to repair this !! I seem to remember there is something peculiar about the clutch hydraulic system on the C5, can anyone elucidate please ?
We can do the repair between us if we know the issues.
C5 HDI clutch problem ?
HDI
- x 7
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 5673
That seems excessive to say the least.
The slave cylinder on the C5 has a bleed nipple on it so replacing it should be fairly simple and it most probably only needs a new seal, rather than a full replacement slave cylinder.
I am presuming that the price includes a full clutch replacement too.
I had a new DMF and full clutch replacement, along with a few other minor bits and pieces, for less than half that.
I would at least be soliciting a few more quotes before commissioning that one.
HDI
- x 7
Ah, so the C5 doesn't have a sealed clutch hydraulic circuit like the Xantia 2 then ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 5673
hdi_man
Citroenmad
- x 110
Yes, don't even think about touching it yourself. Get it into the dealer for warranty work. The clutch cylinder wont be classed as wear and tear items on such a new car.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
HDI
- x 7
Citroenmad
- x 110
Well the Dual Mass Flywheel (DMF) is known to fail at almost any mileage. 30K to beyond 100K is the normal, so why the massive difference in mileage?
Otherwise they should last a good while, i dont think cylinders are a particularly common failure.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
hdi_man
Sid_the_Squid
Too right 30k miles is way to short for a clutch life span, I'd be disappointed if it needed chaining at 80k miles!
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
Citroenmad
- x 110
A clutch should last 100K easily and many more than that too. Needs to be treat right but if the clutch problem is not due to wear then it should be a warranty repair.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
hdi_man
I found an interesting thread where loads of peugeot and Citroën owners experiencing clutch slip also, as it is intermittent it is caused by Oil leaking into the clutch plates and this IS covered under warranty.
however, dealers would not know this without first taking the thing apart...faulty seal apparently
cachaciero
- x 9
PSA seem to have major problems with clutch /DMF. I have been researching some alternatives to my C5 one of which was the Pug407. Clutch / DMF failures at low mileages appear to be of almost epidemic proportions, often it seemed repeated at similar low mileages after having been changed / replaced under warranty by main agents. I see no reason not to expect the C5 III to suffer the same.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
old'uns
- x 127
does the Fffff...mmmmmdo still use the same engines as Cit/Pug, if so do they use same gearbox or clutch system?
work colleague of mine recently bought a 140 est. with 4k on it, 4 months later at 30k clutch started slipping.
in to dealers under warranty, Henry's tech dept told dealer to strip out, clean up & re-fit, guess what? didn't work.
they were then told to replace parts, all fixed.
however when asked what the problem was 'errrmmmm.... well... it's fixed now', all very vague
common problem with Ffff... as well?
Citroenmad
- x 110
It will be the same gearbox and clutch on the 140 Mondeo, its the same unit.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
