01,406 Hdi fuel guage
x 1240
Unread post by Peter.N. »
Hi again
My reliable 406 seems to be letting me down this week. Filled it up with fuel a week or so ago, the level had dropped to just above half full, a couple of days ago I noticed it was reading full again, so unless the diesel fairy has been round during the night, I think something must have gone wrong. The remaining mileage reading seems to have gone up as well so it seems sensor related but I have noticed today the the gauge is dropping slightly, reading between full and 3/4. Any suggestions?
Peter.
fynnbar
Unread post by fynnbar »
Could well be the sender unit. It's part of the in-tank fuel pump, and they go wrong for a pastime. Either the unit develops a fault, or the plastic locating tab for the float arm breaks, allowing the arm to do whatever it likes.
2004 Dispatch 110 HDi
x 1240
Sounds a possibility - thanks
Toby_HDi
x 3
Unread post by Toby_HDi »
The other possibility could be an electrical gremlin.
Try disconnecting the battery overnight. If that fails, there is a BSI reset procedure which may work.
A quick search on Google will reveal the procedure.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 1240
It spontaneously healed up tonight. :?
fynnbar
Then it probably is a wiring fault, and it probably will happen again, Pete ...
