Help and advise needed
bxman
Unread post by bxman »
My 1.8 16 v stopped while at traffic lights late last night in the rain
and would not restart. People kindly pushed me into a filling station .
It may have happened while coasting into the lights certainly more than 1200 rpm and there was no noise apparent until attempting to start.
no real complaint ( 225.000 on the clock)
The cam seem to be broke in that the belt is still round the sprocket ( but with cover prized back ) it wobbles about.
I tried the starter 3 times and initially though it was the starter motor come lose and the noise came from that.
Would I have bent the valves or done any other damage ?
Probably in total 4 , 5 second bursts .
New prices frighten me so,
If I fit a second hand cam do I need brand new followers ?
I have other engines in identical cars and am inclined to pull one of those and take the opportunity of fitting a new clutch at the same time .
All thoughts/ advise/ experience most welcomed.
x 8466
On a 16V Patrick, there will have been severe valve damage if the belt has gone.
I'm not at all clear as to what's happened. The cam is broken you say but is this from looking at the cam or from observing movement on its drive sprocket? You say it wobbles about. What wobbles? The sprocket? Don't forget these are vernier sprockets and the adjustment may have come loose, allowing the outer to become loose with respect to the inner.
These have two camshafts. Have both suffered?
The only way to find out what's happened is to have the lid off the cambox and to remove the belt covers and then check timing.
If the worst has happened than you can consider the engine a writeoff. Best to source a spare one from a breaker and swap them...
x 94
Unread post by citronut »
as Jim says get the belt covers off and try setting/peging the timming up,
and Jim looks like Patric has his own breakers, so if the worst has happend just swap the hole lump,
regards malcolm
bxman
Thanks malcolm and Jim
the belt appears to be intact It is the sprocket that wobbles only the inlet cam affected the belt still has drive.
The front cam does not rotate as viewed through the oil filler cap. When rocking the engine back and forth in gear
Plenty of "graunching" noise from that area as well.
x 94
you need to follow the first advise then get back to us,
cam and belt covers then set cam timming, even though the belt looks ok it can still have jumped some teeth,
regards malcolm
x 8466
citronut wrote: even though the belt looks ok it can still have jumped some teeth,
Yes, or the vernier has come loose...
bxman
update
The cam itself is untouched It was the sprocket that sheered it's 3 spokes
the belt was unmarked likewise the cam have fitted replacement end spigot (which got a bit chewed up) to cam and a fresh sprocket but sadly it has yet to spring to life.
It might be getting a good tow up the road in the morning.
x 94
i would check the cam timming,
if the engine has been cranked over with a broken cam sprocket, you will have almost certaily ben valves on that bank,
if you dont check it out in depth you might do more damage,
valve clearance's, belt timming, compresion test,
not necerceraly in that order,
regards malcolm
bxman
cheers malcom
Not a scrap of compression on any cylinder It looks as though all 8 inlet valves are bent, or at least one in every pot.
Deanxm
x 87
Unread post by Deanxm »
its almost a dead cert, because on 16v's the valves come in at about 60Deg to the piston crown it only takes the slightest contact to bend them, that and the valves are tiny and not very strong.
Seem strange the pulley broke, was there nothing that jammed the camshaft which resulted in the pulley breaking? not that it matters now as its a head off job if there is no compression.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
addo
Sara Watson's Stalker
x 95
Unread post by addo »
As they open in unison, cylinder pairs will be bent. It's easy to find 8V replacement valves, but 16V valves may be specialised aftermarket or dealer parts (maybe 12-13 squid times eight). Specific LPG/petrol engine valves are much dearer.
Your cam and hydraulic followers should be fine.
x 8466
Oh dear Patrick :cry: That's a shame...
Off with 'er 'ead and see the extent of the damage...
x 94
as long as the second cam continued to rotate in sink with the crank, it will not have bent any valves on that bank,
but i suspect as the one sprocket was doing its own thing it will upset the belt timming,
regards malcolm
