Folks,
'95 non-hydractive.
I have just changed 4 x corner spheres, as ride was becoming harder.
Accu one last changed 2005, and anti-sink 2009.
Despite this, I can really still feel every bump in the road.
There is a stark difference between how it's been in the past having changed the spheres (superb ride), and now.
Have exercised up/down to full extent a few times....LHM level is at top mark at highest position.
Did full filter/reservoir clean/Hydraflushing system 2009, and has recond pump fitted last year.
If anyone has ANY ideas as to what I can try, I would really appreciate it.
Many Tks, Steve
Xantia - Hard Ride
StevieM
Xantia - Hard Ride
- x 94
StevieM
- x 1240
StevieM
up on axle stands now:-
"hight corector linkages/turrets nice and floppy free,"......
If this describes all in that cluster of linkages, plastic clip,cylijnder thinghy just in front of the spare wheel, then I have always kept this lubricated.
Must admit, nothing in that area is really "floppy free", but I have sprayed it all with lithium grease, including the springs.
If there is another area I need to look at, please shout!
With regards to ride height......driveshafts, and rear suspension arms (pointing along the length of the car) all seem horizontal at normal ride height position.
tks, steve
tks, steve
- x 8459
StevieM
Have 3 fingers front, 2 at rear.
Struggling to understand Haynes with regards to rear "H2" measurement check.
The text states...."between ground and the part of the vehicle underside above the rear rubber mounting", but the illustrations are as follows (apologies....P-bucket as rotated them 90deg for some reason!):-
!st shows a portion raised from chassis...I dont have that.
2ns shows measurement up to the bottom of the "cup" holding the rubber mounting.
If I take the 1st option actually onto the chassis that the mount is bolted to, it is 415mm (making my "L2" 140mm...out of spec, as '95 model should be 121mm) if I take the second option...it is 395mm.(ie making my "L2" 120mm...in spec)
Please advise if can guide me.
MANY tks, Steve
MANY tks, Steve
StevieM
- x 8459
No, it looks too high both front and rear!
Was that really three fingers at the front? You sure it was not three complete hands
Ride height makes a tremendous difference to comfort but before making any adjustments, go over your height correctors very thoroughly and check they're working properly by firstly sitting on the boot sill and checking the car sinks under your weight and then rises back up after 15s or so. Similarly, when you get off the boot sill the rear should rise considerably and then fall back to normal after 15 seconds or so. Repeat at the front in the same manner by sitting on the slam panel although the excursions won't be quite so marked due to the engine weight vs your weight. All tests with the engine running.
Until these tests are good, don't attempt to adjust height. If the tests fail the problem will be stiffness in the height corrector mechanisms or dirt in the height corrector hydraulic valves themselves, especially if the response to height changes is very sluggish - say, in excess of 45 seconds or so.
- x 94
Rhothgar
- (Donor 2026)
- x 222
Old-Guy
- x 33
Definitely too high at both ends; it looks to be in Intermediate or High.
Without insulting your intelligence, let's start at the beginning:
1. Given that the height control lever positions aren't marked, is it set in Normal? (from the front the positions are: Low, Normal, Intermediate, High). Low and High are for workshop use only. Intermediate is for only for negotiating obstacles at low speed (there's only about ½" of suspension movement!)
2. When you 'exercise' (Citerobics) the suspension, pausing for at least 20 seconds at each settings, does the car actually go right down on Low?
3. Is there a difference in height between Normal and Intermediate (the difference between Intermediate and High is quite small).
I too found the Haynes explanation complicated and confusing; there's a 're-interpretation' on my website and also a separate Quick Suspension Height Check that doesn't involve getting under the car.
StevieM
Old Guy,
Thanks for that.
Definitely in the Normal position...I have lots of movement at front, less (5-6") at the rear.
Hi/Lo limits....will reach these with no issue.
Difference between Normal and Intermediate....good point....suppose this will prove correctors are sensitive enough to very small changes....will chk this.
I will next have some free time in a couple of weeks.
I really wish there was more clarity in Haynes manual on how to measure the rear height.
The front is clear on how to measure, taking into account different tyre sizes.
I can get to the rear clamp on the anti-roll bar easily (front one looked bit more tricky from memory???)
If only I could obtain information on what exact point I should be measuring to for the rear from somewhere (my cay is 10/95, so believe the "L2" should be 121mm...just don't know where to measure to as per previous post), I will put car up on stands (I don't have any ramps), douse clamp in penetrating oil, and try to shift it slightly, put car down + re-asses. (then repeat)
It's really don't mind doing this, if I could be confident what I was measuring to.
It's gonna be cumbersone, but the only way I can see to do it safely.
Many Tks, Steve
Thanks for that.
Many Tks, Steve
Xaccers
- x 188
Check for any play on the dog bones too.
Recently replaced Cassy's rear one as it was quite loose. I was able to roll it left and right.
The new one is much tighter.
DIY sphere tool
DIY sphere tool
