Car is 1996 306 TD Spinnaker with 52,000 miles. The airbag warning light flashes for about 4 minutes then stays on every time. When I got the car it used to be intermittent, but now it is every time the car is started.
I believe this is usually the airbag trigger wire under the driver seat needing new connectors.
Is this something I can do myself after disabling the airbag per the Haynes manual or leave it to a garage. My local garage would not look at it though - is a trip to Peugeot dealer needed?
Any help most appreciated
Michael Goodlad
306 TD Airbag warning light
Hiya... As I understand things , the light is indicating a fault in the circuit. I would say the first thing to do is do a fault code check and that ought to point you in the right direction...even if it is just down to the connectors. As you mentioned though, pay close attention to the safety procedures even BEFORE you start playing with those connectors, just to be on the safe side... its really just a case of disconnecting your battery..leaving all alone for 5 mins..before you start work on any part of the airbag system....that will give time for the airbag (cant think of the word!!!)....erm.... capcititors I think... to discharge! ( the things that fire the airbag anyhow!)
Let us know how you get on...
regards
Mike ps. be aware that disconncting your battery you will drop your radio code.
regards
Hi Michael,
Im sure you are familiar with eBay. I have jsut seen about three fault code readers that will be ending in a days time. No let me look again, there are hundreds all from the same seller. Starting bid is 16.99 with small delivery costs.
They look basic but should do the job, Draper are a good make. (The tool company)
I have the same problem with my 306, so I might also try it. Up until now i just shove my frontseat hard back and the light goes out occasionally. After reading this tho, i will probably treat my airbag system with more respect.
Hope this helps. Tim
Thanks Tim -don't worry - I am still here and still have the problem - I have lived with it for 2 years now... Once or twice I have disconnected the connectors under both the drivers and passenger seats, sprayed some contact cleaner into the connectors - usually fixes it for a week or so, then back to normal. I really just ignore it these days.....more pressing problems - alarming clunks coming from the 106! That is very interesting the fault code readers on ebay and will check it out - thanks.
Regards
Michael
1996 306 TD 66,000 miles
1996 106 1.5d 85,000 miles
Regards
Michael
my renault safrane has this recurring problem ,the first time a self
employed mechanic reset the board computer {9 faults} for a crate of beer 9 euro`s it started up again yesterday so I disconnected the
battery waited 15 mins then pulled all the connectors apart and sprayed them with contact cleaner.
