Xantia coolant/temperature STOP warning
redzzed
Unread post by redzzed »
Xantia 1997 1.9 td a/c
The red STOP warning light comes on after a while , usually before this the yellow 'temperature warning' light on the dashboard comes on.
The temp gauge goes up to 70 degrees C but no higher and the coolant is full up to the mark.(the water is brownish and a little has oozed out).
the car continues running normally , no steam etc.
I'm hoping that this is a thermostat prob or sensor error.
Anyone know ? i can't really afford any big fixes.
I don't seem to have any leaks , the car has air conditioning , which i don't use .
This happened first about 3 weeks ago on the motorway on a cold rainy night and i stopped and put about 1/2 pint of apple juice in , which was the only fluid i had , and the light went out .
any advice welcomed thx .
has anyone else had this problem
current : 1997 xantia 1.9 td sx a/c
previous cars :
1997 zx memphis td
1996 zx volcane td
1994 zx volcane td
Xaccers
x 188
Unread post by Xaccers »
Happens to Cassy now and again, most likely a dodgy earth, but I believe if the rad fans are misbehaving it can also bring the stop light on.
Idle the car, turn the A/C on and the fans should spin slow, keep idling until they kick in fast and see how they're doing.
DIY sphere tool
x 1240
Unread post by Peter.N. »
The connections on the temperatur sensor can go crusty, all my XMs have had this problem intermittently, I sometimes get an 'overheating' warning when I have just started it! Providing the temp gauge reads OK I ignore it.
x 5689
Peter.N. wrote:Don't know what that rubbish is, nothing to do with me.
Taken it out of your avatar file Peter.
Steve.
x 1240
Thanks Steve, how did it get there?
Xaccers
x 188
Peter.N. wrote:Thanks Steve, how did it get there?
the jpg you used to have as your avatar hasn't existed for quite a while, so now we've activated the new 404 error image, your avatar being missing was causing a 404 error, and so showing the image.
Now your avatar link has been cleared there won't be a problem.
DIY sphere tool
x 1240
Oh, thanks anyway.
redzzed
Thx for the replies .
i started it today and left it running with the ac on , the warning came on later .The temp went up to 90 degrees , but by now the STOP and yellow
lights had gone out again , and also the fans had not cut in .
I took it out down the road for about 4 miles and the temp went down to 70 again and the warnings came on again , but went off after a few mins .
I'm going to risk it for a week and see how things go , i have an 80 mile drive tomorrow .
sorry about the avatars
previous cars :
1997 zx memphis td
1996 zx volcane td
1994 zx volcane td
Xaccers
x 188
redzzed wrote:Thx for the replies .
The avatar issue was due to Peter not bothering to update his when the original file was lost :D
DIY sphere tool
x 1240
I didn't know it was :?
Xaccers
x 188
Peter.N. wrote:I didn't know it was :?
You had an image place holder like in the missing link photo here:
DIY sphere tool
x 1240
I never noticed much to technical for me :oops:
