I'm sick to death of the windscreen steaming up!!!!!!!
x 8365
brmartyn wrote: This stuff then?
That's the stuff...
That's a good price too :)
brmartyn
Unread post by brmartyn »
That's the stuff...
Would you use the whole bottle in one go?
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
x 8365
brmartyn wrote: Would you use the whole bottle in one go?
Oh yes... All of it... At least, I would...
imperial21
Unread post by imperial21 »
Do you need to keep topping your water up in the engine ??
If not you dont need it !
I used the whole bottle of stop leak.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
brmartyn
imperial21 wrote:Do you need to keep topping your water up in the engine ??
No the water is fine and always has been and the engine temp never goes above what it should be
Brady
imperial21
In that case I would say stopleak is nt going to help you, my car was losing water, i think your have rain water ingress as suggested earlier in your post, but i am no expert !
VertVega
x 13
Unread post by VertVega »
There are some pics in this thread sent by andmcit: Xantia heater matrix renewal
I hope Forte Stop Leak will cure it. I'm very satisfied with their other products (Motor flush, Gas treatment).
hobblerian
Unread post by hobblerian »
I know this might sound a daft suggestion and probably the first thing you checked, but have you checked that your air flow is set to fresh air in and not re-circulate? Two of my friends have moaned to me that their cars have been constantly misty and both have been set to re-circulate. A simple slide of the lever cured it for them.
Previous 90H S1 XM 2.1td SD Manual
Current 97P S2 XM 2.1td VSX Manual
brmartyn
hobblerian wrote:I know this might sound a daft suggestion and probably the first thing you checked, but have you checked that your air flow is set to fresh air in and not re-circulate? Two of my friends have moaned to me that their cars have been constantly misty and both have been set to re-circulate. A simple slide of the lever cured it for them.
Fresh air all the time :wink: :wink: :wink:
Brady
x 1485
If the matrix is leaking, then you usually get coolant dripping off a spigot sticking out of the bottom of the heater box just to the left of the centre console. Forte is dead good stuff, been running it in mine for at least 40k without any further weeping from the matrix. 'Fitted' a new bottle when I changed the coolant as part of the timing belt / water pump change a couple of weeks ago. I have no intention of having the dash out unless things take a serious turn for the worse!!
handyman
Unread post by handyman »
Brady, if you aren't losing coolant, your problems lie elsewhere.
Do you have a sunroof?
Is the boot floor wet?
Lift the rear seat swabs and see if the carpet is dry.
Have you changed the internal air filter recently? If not this may be blocked.
Is the lower windscreen scuttle loose or coming unstuck from the windscreen?
Answer these questions and you will get answers to all the potential water ingress problems with the Xantia. They are all easy fixes.
Handyman
sonoramicommando
x 5
Re:
Unread post by sonoramicommando »
CitroJim wrote:
brmartyn wrote:So the Forte Stop Leak would simply be poured into the radiator?
Yep. Into the header tank. You may have to drain a bit of coolant off to make room for it. The bottle contains 500mL if I remember properly.
It's seriously good tackle...
Hi,
I'm getting myself a bottle of this and gonna try this.
But the rep told me to pour into top radiator hose, NOT into the header tank.
Obviously undoing rad hose would be a mess, as well as having to bleed the system I presume.
I gather you guys haven't issues pouring into the header tank, by the sound of it?
Cheers,
Sam
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
lexi
x 134
Re:
Unread post by lexi »
Deanxm wrote:Image
CIMG3125 by Deanxm, on Flickr
:cry:
D
If that is standard of curry carry out you get locally I would take it back :-D
I have slight smell on heater going on and off. I think it is egress without much loss of coolant.
The forte is in mine.
Valeo must be the worst matrix of the lot. Troublesome in range rover too. They even instruct you to put k seal in with the new matrix :shock:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
MPV
Re: I'm sick to death of the windscreen steaming up!!!!!!!
Unread post by MPV »
Another possibility for the misting up is a blocked pollen filter. These are supposed to be changed regularly. On my Synergie last summer I could not demist the screen in damp weather. Changing the pollen filters cured the problem. They had not been changed in at least 5 years!
Synergie XUD9 - the "Duck-billed-clatterbus"
x 5671
Could also be a partially blocked drain from the aircon/ventilation system.
