Xantia HDi smoking
HDI
x 7
Unread post by HDI »
No wonder it flies !!! I wonder if the map sensor is reading correctly though ?
Even if it is the ECU should go into limp home as a result of overboosting.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
When I get the chance I'll connect up my Lexia, go for a drive and compare readings.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
DHallworth
x 167
Unread post by DHallworth »
Don't worry to much DickieG,
I'll plug it into our SX tomorrow and compare it with that.
Paul's told me that the boost sensor is on top of the intercooler so I'll have a look at that tomorrow too.
Does anyone know if leaving those metal plates I fabricated across the EGR will cause any damage?
Ta!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
HDI
x 7
No, they won't. EGR is just for emissions.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
DHallworth
x 167
HDI wrote:No, they won't. EGR is just for emissions.
Thank god for that!
I think I'd scream if I had to take them out! My hands are sore and covered in scratches after fitting them!
If anyone wants me to fabricate a couple more then let me know.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
dieselnutjob
Unread post by dieselnutjob »
I think it means 2 bar absolute pressure
In other words 1 bar of atmospheric pressure and 1 bar of boost
1+1=2
which is as it should be
Does it still smoke with the EGR blanked off?
By the way just leave it blanked forever. It's better for the engine to not be breathing in carbon particles as they are slightly abrasive.
x 1488
Those pressures may well be absolute (ie atmospheric pressure plus the bit on top) - hence 2 bar is about right.
dieselnutjob
DHallworth wrote: Turbo Pressure Measured: 2014 millibar
Turbo Pressure Setting: ~2000 millibar
the clue is here.
the ECU is trying to set the turbo to 2000mbar absolute. It is actually getting 2014mbar.
So it it overboosting by only 14mbar. i.e. the ECU is getting 14mbar more than it wanted.
14mbar is basically nothing, so the ECU is happy.
If the ECU sees a big overboost it will put the warning light on and limit the engine to 3000rpm to try and protect the turbo. Happened to me once when a vacuum pipe fell off and the ECU lost control of the turbo.
DHallworth
x 167
Does the fact that it's running at 2 bar rather then 1 bar have any significance at all or am I just being thick again?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
dieselnutjob
2 bar absolute is 1 bar above atmospheric pressure so it's perfect.
Measure it with the engine not running or idling and it should say 1 bar.
The only way you'd ever see zero is in a complete vacuum, which ain't happening.
DHallworth
x 167
Of course, that all makes sense now.
This gets more puzzling though.
As suggested, if the timing was out there would be fault codes registered.
The EGR can't be causing it as it's doing the same with it blanked off.
The boost pressure is spot on.
The car doesn't use a drop of oil.
I'll try and check the compression tomorrow as also suggested by Dieselnutjob and will compare that to the compression on the SX.
When starting the car in the morning when it's cold it occasionally catches on 3 cylinders, when revved gently though it always takes on the 4th. I only noticed this when it was very cold though.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
dieselnutjob
DHallworth wrote:When starting the car in the morning when it's cold it occasionally catches on 3 cylinders, when revved gently though it always takes on the 4th.
I'm afraid that's not right. Could be a stuck hydraulic tappet as easily as rings though, or even a glowplug I suppose, but that would only affect it when it first starts.
DHallworth
x 167
It only does it when it first starts.
As soon as it's been running for a second or two it runs on all 4 normally.
I'll try and get a video of it cold starting tomorrow.
It was that which led me to replace the glow plugs and the glow plug control box.
No matter how cold it is the light flashes on for 1 second then goes off. In the really really cold weather it was taking several wacks of the glow plugs before we even attempted to start it.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
HDI
x 7
dieselnutjob wrote:I think it means 2 bar absolute pressure
1+1=2
Oooop's, I was thinking boost gauge reading !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
HDI
x 7
DHallworth wrote:It only does it when it first starts.
David.
Definitely not typical of an HDi, the colder it is the longer the glow light stays on and even on the coldest day in December mine fired first turn and ran on all 4. There is a clue to something not being right here.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
