As the title says really. Went to leave for work this morning and turned my blower on whilst I attempted to scrape the window. Nothing. Didn't matter which setting it was on the fan was not willing to co-operate. Then went to turn on the heated rear window. Nothing. Pressed the button and the light wouldn't come on. So I can't see forwards or backwards! Is it coincidence that they have gone together or is there a common link?
Cheers all.
Xantia Blower & Heated rear window simultaneous failure
Penguin
95 Xantia 1.9td SX
Johnny Cogs
Penguin
- x 1485
Whilst a bit of key wiggling might fix it temporarily, the contacts in the ignition switch are burning out. The proper fix is to install a relay under the steering column shrouds to take the load off the ignition switch (as factory fitted by Citroen on the MK2!). You should be able to turn up loads of posts on a forum search - I used to have a wiring diagram for it, but think I have lost it now - I can make a new one up though easy enough if you want one. In fact I may do a helpful hints post this evening as SWMBO is out....
Penguin
Johnny Cogs
Penguin
Unfortunately Johnny, that's the way I tend to get by as well. So your little tip will hopefully be useful.....until it packs up completely or I get myself motivated to do the mod.Johnny Cogs wrote:Yeah, sorry, I'm a bit of a get you home style pikey..... Proper jobs are for better weather for me!!!Keep us posted!!!
95 Xantia 1.9td SX
- x 1485
This thread covers it pretty well: http://www.frenchcarforum.co.uk/forum/v ... hp?t=17322
Except the link to the wiring diagram won't work any more as geocities is long gone. Not sure I have the diagram anymore - I'll have a look.
Penguin
Thanks for that Rich. I have read the various threads that are linked together and it appears that I need to remove the steering column cover, but to do this I have to take teh steering wheel and airbag off. Is this correct? Is there any way of modding this without doing that? Not at all comfortable with the thought of messing about with airbags.
Cheers
Cheers
95 Xantia 1.9td SX
- x 1485
I've found the diagram, I'll post it up later.
Unfortunately on a MK1 there is no choice but to remove the steering wheel (and airbag!) - unless someone's been there before and not put the screw back in the bottom cowl from the top (top cowl goes around the steering column, and needs to come off first to get to a screw that goes downwards into the bottom cover). It's not too bad getting the wheel off:
Set the steering 90° either way so that you can get access to the bolts in the back.
Take the battery off and go for a cup of tea
Undo the two Torx bolts accessible through the back of the wheel (T40 maybe?) - you might need to cut away the rubber of the wheel to get access.
Lift the airbag clear carefully and unplug it - store it away from the workarea!
Disconnect the radio controls board (bit tricky IIRC)
Mark the wheel and column so you can get it back on in the right place
Undo the steering column nut (21mm deep socket required) - it can be tight! Leave the nut on the end of the thread (important this bit - if you don't you risk smashing your teeth and / or wrecking the wiring to the air bag / radio when it comes free!).
Wiggle / bang from behind the wheel to free it off the splines, remove the nut, then thread through the wires and remove the wheel.
Try not to disturb the rotary connector whilst the wheel is off, otherwise it might end up in the wrong place and break the internals at full lock when refitted.
Refit is reverse of removal.
Sounds a lot, but in reality the cup of tea takes longer than getting it off!
- x 1485
Wiring diagram with info now uploaded: Fan mod wiring diagram
Penguin
Could just be me, but the link doesn't appear to work.RichardW wrote:Wiring diagram with info now uploaded: Fan mod wiring diagram
The fan started working again when I started the car after work, so I guess that oretty much confirms the contacts.
95 Xantia 1.9td SX
- x 1485
Should work now.... Think I have had trouble with that before - in Preview the forum capitalises the X in Xantia, but then it doesn't in submit - so I changed the URL on the webserver to match, which it then didn't as it then didn't capitalise the X when I submitted the postPenguin wrote:Could just be me, but the link doesn't appear to work.
Penguin
