A Xantia is in my life again......
FuzzyEdges
Unread post by FuzzyEdges »
Afternoon,
After 'downsizing' and starting my own business I find I have a Xantia 2000 HDi SX sitting on my drive as cheap reliable transport, I hope!
The last Xantia I owned was a 1994 1.9TD VSX during 2000 to 2003. I manged to complete 178,000 miles in that car before selling it.
I've been reading and searching the forums but still have a couple of questions.
first one - I need replacment glass for the drivers side mirror.
It is electric, has a heating element and a blind spot section on the edge.
Could anyone recommend a supplier that doesn't charge a fortune?
Second one - The front electric windows don't work, could anyone post a link or supply me with a colour wiring diagram so I could trouble shoot them?
Many thanks in advance,
FuzzyEdges.
Citroenmad
x 110
Unread post by Citroenmad »
Welcome to the FCF :)
Wow, 178.000 miles in 3 years?!?! Did you ever get out of it? :lol:
A would bet a motor factors would be able to source you a mirror glass quite cheaply.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
andmcit
x 30
Unread post by andmcit »
http://cgi.ebay.co.uk/CITROEN-XANTIA-RH ... 0124237953
The two front door windows not working sound like a common failure point;
he fact that both sides are innoperative would suggest that either the wiring in
the door jambs from the bodyshell pillars is fine or conversely totally goosed!! :lol:
First off I'd check fuse F27 under the dash and check there's power through
it with a multimeter.
Andrew
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
The passenger window needs power from or through the drivers switch to work..
Has the HDi done big miles?? If not, it Could be a case of sticky window in the Seal. I had this on Xantia - had an SX with 3 working windows for nearly a year, when one day I hit the window switch and the window came down with a thud, it was stuck in the seal..
Big milage would point towards boken wires as Andrew says, between the drivers door and car..
Paul
A very sad...
1994 XM 2.1 d auto
andmcit
x 30
citroenxm wrote:The passenger window needs power from or through the drivers switch to work..
Brilliant Paul - of course - there's a good chance the driver's window switch
on that door is knackered - I'd forgotten the s2's like doing thing a bit
differently to the s1's. :roll:
Andrew
citroenxm
Fallen Hero
x 70
S1's are the same arent they not, OR am I getting mixed up with the XM setup... :roll:
Paul :?
A very sad...
1994 XM 2.1 d auto
FuzzyEdges
Citroenmad wrote:Welcome to the FCF :)
Sorry, bit misleading that statment, I bought the car with 100,000 on the clock and added another 78,000 in three years mostly commuting.
FuzzyEdges
Thank-you for all the replies. It's nice to be involved in such an active forum, I hope I will be in a postion to help others with advice soon.
The car has done 95,000 miles and I've checked fuse 27.
Not having opening windows is a bit of pain when I have to swipe an ID card to obtain access to our company car park!
I'll get the mutimeter out and strart investigating before the snow returns.
x 8339
Hi Fuzzy,
Here are the wiring diagrams for the front windows:
Circuit Diagram
Harnesses
Locations
The four figure component codes in the diagrams can be cross-referenced to the list in the back of the Xantia Haynes manual.
I trust these will help in your fault finding. The harness diagrams are especially useful as they tell you exactly which wires do what.
FuzzyEdges
CitroJim,
Thank-you, thank-you, thank-you!
FuzzyEdges.
