Done, with two of us stood on a 6ft bar it went with a bang, took a lot of lining up and practice goes, also lost two good sockets and the head of the bolt is toast, at least i know the clutch is good though and so is the handbrake, it didnt budge at all.
luckly i had a couple spare but thanks for the offer Richard!
Strange how the anti sink equiped cars seem to have a rather fiddly D pin arrangement for holding the crank pulley in place and no proper way of pinning the crank up with the pulley off whereas the older N/A and turbo cars without anti citroen have a far superior setup which makes things just that little bit quicker and more straightforward, woke me up anyway .
Ive just bid on a waterpump which im hoping to get at a very good price, also the cam belt kit is in transit..............all i need now is some sunshine.
What's wrong with locking the teeth of the flywheel. You'll be going some
to take those teeth off considering what force runs on it off the sterter motor.
As a matter of fact, I have found a chisel popped through a top opening to
lock the flywheel on other petrol engines will normally suffice. That's of course
if there is an opening to start with!
I did find an opening in the end Andrew, there is two thumb sized holes under the car, made to take a chisel , it wont hurt the clutch its job is to transmit torque, it will certainly be taking more punishment than this when it gets on the road
Deanxm wrote: Done, with two of us stood on a 6ft bar it went with a bang, took a lot of lining up and practice goes, also lost two good sockets and the head of the bolt is toast, at least i know the clutch is good though and so is the handbrake, it didnt budge at all.
D
Well that was FT!
WEll done for getting it sorted!
ACTIVA
nout wrong with locking the fly wheel via the starter ring gear (if you can get at it ),
but i still feel holding the engine on the clutch with brakes hard on, then crank the starter to undo a crank pully bolt, could damage the drive plate,
i have seen a BX D with a completly shatterd clutch plate through the owner repeatedly bump startting the car, turned out just because it needed glow plugs,
