Lexia C1 / 107 / Aygo
spider
x 77
Unread post by spider »
I was just wondering ;)
Does the Lexia (or indeed the Planet software) function with a C1 / 107 / Aygo ? , I would assume so but...
My understanding is these are not multiplexed at all.
I heard elsewhere talk of a ScanGauge, but this appears to be OBD2 and a few other features ?
I guess what I'm asking is, will a Lexia work with a C1 or its 'partners' ? :)
Andy.
Toby_HDi
x 3
Unread post by Toby_HDi »
Bear in mind that a car of the C1's age will be OBD compliant anyway, so said reader should work.
As far as I'm aware (I could be wrong) updates for the Lexia 2 ceased and they will read cars up until 2007. After that and I think the updates would only work with the Lexia 3, hence you'd need one of these.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
spider
x 77
I did wonder but I am half thinking of the HDi unit, hence wondering if Lexia would be better.
I have neither Lexia nor car, I'm just sort of investigating potential candidates choose from (as in Make / Models) , although I do think even the early HDi will be out of my price range. :oops: , although I do not like to have to work the transmission too hard, hence wanting a higher torque unit.
The little petrol unit does seem quite nice, I have been put off 3 cyl units having had a 1.0 Corsa :oops: with one fitted years ago. Although saying that the 3cyl Polo (the 1.2) was quite nice so I should not judge all 3cyl by that.
The only real issue I am aware of is water pumps on the petrol units, although it does not look like its any issue to change at all, apart from a slight space concern.
I think I'm just posting my thoughts now 8-)
Andy.
VertVega
x 13
Unread post by VertVega »
Checked the list of cars from mine and the left side column starts with C1.
(C1, 2, 3, 4, 5, 6, 8, C-Crosser, Nemo, Berlingo, Jumpy, Jumper and DS3)
x 1044
Unread post by wheeler »
Yes Lexia 3 will deffo work with theese & they are not multiplexed either.
